MSD Digital Window Switch - Which wire to which pins on relay?
Old Dec 27, 2005 | 01:53 PM
pianoprodigy's Avatar
Default MSD Digital Window Switch - Which wire to which pins on relay?
I'll be installing my MSD digital window switch tonight. I know I need to use a relay. Which wires go to which pins on a traditional relay? Nitro Dave is closed, or I would call and ask him.
Thanks.
Old Dec 27, 2005 | 10:09 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Not Digital one but the yellow wire is the same for booth units.. Just ignore the FPSS if you do not have one,
Ricky
Old Dec 30, 2005 | 09:26 AM
Scalpel's Avatar
NXRicky, so the gray wire on the MSD Dig box is just left unattached then?
Old Dec 30, 2005 | 09:42 AM
NXRICKY's Avatar
Yes that wire is the normally close Circuit. Use it if you wanted to turn something off in the window.
Ricky
Old Jan 1, 2006 | 09:32 AM
Scalpel's Avatar
So this unit remembers the settings it was programmed b/c there's no constant power to this unit, is there an internal battery?
Old Jan 1, 2006 | 10:35 AM
227Hawk's Avatar
NXRICKY
You have some of the best diagrams. They should be threaded to gether and stickied
Hawk
Old Jan 1, 2006 | 11:03 AM
Jared22's Avatar
I'm definently saving that diagram!
Old Jan 3, 2006 | 12:03 AM
NXRICKY's Avatar
Originally Posted by 227Hawk
NXRICKY
Hawk
Thank you very much,
I have book of over 60 diagrams and growing ever time I create a new one.
Ricky
Old Jan 8, 2006 | 05:40 PM
Nakoz's Avatar
Hey, since we are on the topic of digital switches. I just installed mine the exact way the diagram shows but i am getting some weird readings on my box. At idle it is showing .37-.39 on the box. When i move up in the rpms the box goes up but it reads some weird numbers. Any suggestions?
Old Jan 9, 2006 | 09:00 AM
NXRICKY's Avatar
If the unit works at the rpm you have set, you are more than likely picking up electrical noise. I have not had the chance of working with the digital msd unit yet.
Ricky
Old Jan 9, 2006 | 09:01 PM
BadAssFast's Avatar
Can a Shift Light be wired to an MSD window switch? Need a module + light?
Old Jan 9, 2006 | 10:47 PM
NXRICKY's Avatar
sure, any thing you want to turn on and off can be.
Ricky
Old Jan 10, 2006 | 12:22 AM
oange ss's Avatar
do you have the cyl mode configured correctly ?
