Wet system Nozzle mount question
Old Dec 29, 2005 | 10:11 AM
WS6HUMMER's Avatar
Default Wet system Nozzle mount question
I want to mount my nozzle now but I have the stock air induction hose from the lid to the TB and the stock one is accordain shaped on the outside, I cant see any possible way to mount my nozzle without buying a smooth Bellow? Is there anything I need to know before I go buy a smooth bellow?
TIA
Hummer
Old Dec 29, 2005 | 10:18 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
What you can do is drill a hole throu your hose clamp and the back side of your maf. Then tap.. Put the unit back on the car with nozzle installed and you are good to go..
Rigid mount, clean look, and no need to purchase a smooth belows...
Ricky
Old Dec 29, 2005 | 11:00 AM
WS6HUMMER's Avatar
Ricky
Thanks!
Ok, so drill a hole trough the hose clamp,rubber, and the MAF end that the hose clamp clamps around? Then tap the alluminum maf end for the thread pitch that's on the nozzle? Just wanna make sure I understand correctly before i drill anything out.
Old Dec 29, 2005 | 11:03 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
You could still mount it in the rubber bellows if you use a fogger nozzle mount with nut.
It should have come with your kit. What kit are you using? Ricks idea works as well...Just wondering...
Dan
Old Dec 29, 2005 | 11:09 AM
WS6HUMMER's Avatar
Dan
I'm using a fogger nozzle, its in the CFN wet kit. The factory bellow is accordian style, the only way I can understand what you're reccomending would be to drill in between the folds and tighten the nut up untill it forces the rubber around it to become flat. Am I right?
Old Dec 29, 2005 | 01:36 PM
Robert56's Avatar
Correct, standard procedure. However, if it were my set-up, I would opt for mounting as per Ricky.
Robert
Old Dec 29, 2005 | 02:25 PM
WS6HUMMER's Avatar
Robert
Thanks! Think I'll do it this way, it will put the nozzle further away from the TB which will be better for atomization, look pretty clean,and I can plug the hole if for some reason I need to remove the nozzle.
Old Dec 29, 2005 | 02:28 PM
NXRICKY's Avatar
Thanks!
Depends on the nozzle if its NX 1/8 npt, some others are 1/16npt.
Ricky
Old Dec 29, 2005 | 02:30 PM
WS6HUMMER's Avatar
Ricky
Thanks Ricky, once again you have really helped me out!
Old Dec 29, 2005 | 02:36 PM
scalemaster's Avatar
here's mine
Old Dec 29, 2005 | 02:39 PM
WS6HUMMER's Avatar
Originally Posted by scalemaster
here's mine
Very nice, 2 stages! I cant tell from the angle but where are your nozzles going in?
Old Dec 29, 2005 | 03:25 PM
I have Dave's 90 mm dual nozzle ring
