nitros quesiton
Old Dec 30, 2005 | 12:11 PM
tboysen00's Avatar
Default nitros quesiton
with a cammed car, 12 bolt and 4.10s with a 150 shot, what all do i need to change for the nirtos, the driveshaft? fuel injectors? anything else. thanks troy
Old Dec 30, 2005 | 12:17 PM
227Hawk's Avatar
Wet you can probably stay on your injectors.Cam only should be fine for duty cycles.
Dry 150 and a cam i would be concerned for fuel. On either an upgrade in fuel pump and a FPSS are CHEAP. The cost of knocking out a cylinder or worse is going to be
alot more.
My .02
Hawk
Old Dec 30, 2005 | 01:43 PM
oange ss's Avatar
any further advice will cost you the 'Cuda....
Old Dec 30, 2005 | 02:19 PM
brad8266's Avatar
If you go with a wet kit, just get a high flow fuel pump and you will be ok, another good idea would be to pull a few degrees of timing. Be sure to use a window switch.
Old Dec 30, 2005 | 03:53 PM
solocam's Avatar
tr-6 plugs and at least a walbro inline.plugs are 15 bucks pump 129.00
Old Dec 30, 2005 | 03:56 PM
solocam's Avatar
you can run a T.N.T. wet 100 with just the plugs.
Old Dec 31, 2005 | 11:40 PM
BadAssFast's Avatar
WET or DRY may require different parts. Specify pleeeze.
Old Jan 1, 2006 | 12:48 AM
brad8266's Avatar
Dry: Injectors, pump, plugs.
Wet: Pump, plugs.
