test results:nx noid vs dynotune noid
Old 01-19-2006, 06:18 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
cbrtrx - What a pleasant surprise! Thanks for the info - it is appreciated! Looking forward to the testing on our smaller noids.
Thanks for all the good words guys! We always welcome people to test and compare our products. Feedback is helpful as we strive to satisfy the needs of the customer.
If our solonoids failed at 1000 psi we would not be going in our 6th year of business. Though I must say we have seen people hook up our fuel solonoids to the nitrous pressure and our fuel solonoid will fail at 1000psi. But most likely so would everyone elses.
Dean
Old 01-19-2006, 06:38 PM
383LQ4SS's Avatar
Originally Posted by Matt@HSW
I thought the new vette MAF kit came with the smaller orifice 'noids?
Matt
You may be right on that. I havent seen that setup up close. It does say it has jetting to 250 hp. They look like the smaller ones...but may be something a lil different since they seem to be intergrated. Ill have to let Ricky elaborate on that.
But the standard kits come with the lager style.
Old 01-19-2006, 06:40 PM
383LQ4SS's Avatar
Originally Posted by ITSTOCK
Is it true that the dynotune noids fail with nitrous pressure above 1000psi?
Nah...the one I smoked with my nitrogen push stopped opening somewhere around 1300-1400 psi after it was already very hot.
I had previosuly used it up to 1200 psi on my dry system with no problems.
Old 01-20-2006, 08:10 AM
TNTramair's Avatar
Originally Posted by Robert56
What I got out of the read was, that NX quality/price is being challenged from all fronts. We all know NX has quality stuff, however, many other companys are offering equal products at a more reasonable price. Meaning, like the vette, NX commands a price, just for being NX. Some of us will still go for the vette/nx over something else that may provide the same quality or performance. Some, will look for the bargain, which I do in certain things as long as quality is there. This is a great time to be involved with nitrous, that's for sure, as the end user has more options than ever before. I have been satisfied with both my NX and Dyno Tune products.
Robert
agreed.
Old 01-20-2006, 11:01 AM
NXJeremy's Avatar
On the one piece MAF it uses the smaller coils but the orifice in the plate housing are larger than our regular small solenoid (or any other small solenoid on the market). That's why it's capable of 250rwhp. The only thing from the small solenoid that is used is the coil and piston.
Old 01-20-2006, 11:09 AM
Nitro Dave's Nitrous Outlet's Avatar
This is why I always say there is more to parts that an outside view... You can not see things like this by just looking at a part.
Dave
Old 01-20-2006, 03:57 PM
Robert56's Avatar
We should also graph out all the different noids from each company ie: orifice size, amp rating, price, body material, seal material and the such. then we can have a reference base. what do you guys think?
Robert
Old 01-20-2006, 04:42 PM
That would be good idea. However some manafactures may not want to help in this. I knwo as a buisness I would not give out all my secretes so that that some other company could just copy what took hours or years of research to develop. There are companys that just copy others. So it would not pay off for the leading companys to tell all there secrets.
I know I would not.
Dave
Old 01-20-2006, 05:26 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
Yep, they do. It's the basic same small noid that Cold Fusion uses.
Robert
wrong, nope, incorrect sir.
Ricky
Old 01-20-2006, 05:29 PM
Robert56's Avatar
Ricky
Can you, or would you elaborate?
Robert
Old 01-20-2006, 05:46 PM
Ricky. Shhhh dont tell all the secrets.LOL
Dave
Old 01-20-2006, 05:57 PM
  #32
Moderator
jimmyblue's Avatar
All I see is, if the 'noid orifice area is much greater
than the jet (here, about 2.25X) then performance
is unaffected. That's normal.
Quick Reply: test results:nx noid vs dynotune noid
