FJO 2stage Mini-progressive Review...
Old Jan 30, 2006 | 10:19 PM
ITSTOCK's Avatar
Default FJO 2stage Mini-progressive Review...
BUY IT
I don't know what else to say! This thing is awesome I just got done installing it, and it really blows my mind. I think I wasted a full bottle playing with the damn thing, while my car was off!! That pretty much sums it up! Full RPM progressive, to multiple time ramping, to shift lights, to a/f inputs (sprays between x.xx and xx.xx just the the dynojet WBC, only with full window switch), 1st gear lockout, everything you will EVER NEED for nitrous, for only $206.
I don't know what else to say, I'm really speechless. There are too many features to keep track of, check it out here...
http://www.fjoracing.com/products/2stageminicontroller/
and buy it here....
http://www.nitrodaves.com/outlet/pro...&section_id=24
Mods, if the last part of my post is against forum rules, please delete the last part
Thanks,
Steve
Old Jan 30, 2006 | 10:59 PM
Robert56's Avatar
Originally Posted by ITSTOCK
BUY IT
and buy it here....
Thanks,
Steve
The only part against forum rules is, you can't mention Nitro Dave's name.
Robert
Sorry, just couldn't help it.
Old Jan 30, 2006 | 11:04 PM
70Stang's Avatar
I just ordered mine today...Thanks DAVE!
Old Jan 31, 2006 | 12:29 AM
Nmbr1GMfan's Avatar
Everything? I have come up with a want. The ability to save and reload previously made progressive graphs. TODD
Old Jan 31, 2006 | 12:59 AM
70Stang's Avatar
Damn...it doesnt have that??
I figured it would...I was going to have a street graph and a track graph as well as a roll one...
hmmm I wonder if it is do-able.
Old Jan 31, 2006 | 01:53 AM
98cobrakillata's Avatar
can it retard your timing for larger shot 200+ like the timing tuner does, this thing sounds way better and its cheaper.
Old Jan 31, 2006 | 08:35 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
use stage 1 wiring for street,,,, stage 2 for track,,, not sure what roll one is. lol
Ricky
Old Jan 31, 2006 | 08:38 AM
Race Car Driver's Avatar
11 & 7 Second Clubs
Mine is installed and working, but haven't figured out how to do all things you've mentioned here.
Old Jan 31, 2006 | 09:20 AM
NXRICKY's Avatar
Hope this helps.
Ricky
Old Jan 31, 2006 | 09:44 AM
redbullapril23's Avatar
whats difference between this and the maximizer 2?
so this allows you to ramp the n20 % vs rpm?
this pulses the solenoids correct?
thanks your friend
Sean
Old Jan 31, 2006 | 09:50 AM
11 & 7 Second Clubs
Ricky,
Thanks for the diagrams:
1. We are using 15hz for our NOS Cheater noids, rather than the 16hz you show here?
2. We are spraying thru the 6800 shift,
3. We are using rpm based.
Old Jan 31, 2006 | 11:18 AM
NXRICKY's Avatar
thanks your friend
Sean
Sean the M2 allows for alot more inputs to control the system. Data logging, gauge inputs, heater purge controls, mutli gear ramps, and alot more.
Yes N2O vs rpm or time.
Yes pulses the solenoids.
Ricky,
Your welcome.
15hz is fine, each set of noid can be driven at different hz. On a dyno you could see what going to a high hz will do for you if the noid can handle it. The higher the hz the clean the transition is.
Hope these help.
Ricky
Old Jan 31, 2006 | 11:38 AM
95ttoplt1's Avatar
Originally Posted by NXRICKY
Your welcome.
Hope these help.
Ricky
Hey ricky can you elaborate more on the frequency thing or maybe start another thread on it. How do you know if the noids are handling it and the gains from going higher or lower.
Thanks
Troy
Old Jan 31, 2006 | 03:39 PM
11 & 7 Second Clubs
Apparently the FJO unit operates at 14-22hz, and I will assume that, if the noid will handle it, we should run the highest hz possible.
Old Jan 31, 2006 | 04:00 PM
Dragframe's Avatar
Hope this helps.
Ricky
those black dots just splices?
Old Jan 31, 2006 | 04:13 PM
NXRICKY's Avatar
Thanks
Troy
https://ls1tech.com/forums/showthrea...00#post4177700
yes connection points.
Ricky
Old Jan 31, 2006 | 04:47 PM
11 & 7 Second Clubs
Thanks.
Old Jan 31, 2006 | 08:37 PM
wheres the cheapest place i can buy the FJO controller?
thanks alot your friend
Sean
slimshaby@mindspring.com
Also thanks Ricky that thread taught me alot!
so i guess the point of frequency control is with a smaller shot a shorter window woudlnt be nice but with large shots then you want the window to be more drawn out and soften the blow of the n20 a bit more...
Old Jan 31, 2006 | 08:56 PM
NXRICKY's Avatar
Any NX dealer has them, but on this forum it would be Nitrous Outlet, or Tbryne Motorsports.
Ricky
Old Jan 31, 2006 | 08:59 PM
thanks!
your friend
Sean...
new rear rims and tires can wait!
haha i though i had to buy the maximizer 2 but i dont so i think ill buy this!
what a great buy!
