Throttle Position Sensor Location
Old Jan 31, 2006 | 09:26 AM
Gabriel's Avatar
Default Throttle Position Sensor Location
Ive searched all of the forums and can't find where the throttle position sensor is on my 02 TA. I need to connect a wire to it with my Zex kit so help would be appreciated. Thanks.
Old Jan 31, 2006 | 09:31 AM
DERTY's Avatar
The Bull
The TPS is on the driver side of the throttle body. It's a round black sensor screwed to the side of the throttle body.
Matt@HSW's Avatar
I believe it's:
Red Connector on PCM, pin 24, Dark Blue Wire
Matt
Old Jan 31, 2006 | 09:33 AM
DERTY's Avatar
The Bull
That would be another place for it. I believe it's the only solid dark blue wire in that connector to. An easy continuity test between the sensor connector and the PCM would confirm that.
Old Jan 31, 2006 | 04:28 PM
bad6as's Avatar
eather the pcm or on the t/b
(pcm imo would be better)
Old Jan 31, 2006 | 04:46 PM
bad6as's Avatar
Old Jan 31, 2006 | 05:27 PM
fstphx's Avatar
I dont mean to hijack the thread but...
whats the voltage change on this line-
say 0-12 depending on position
I wouldnt think a digital signal-
im just thinking i could easily build a tps switch- cheaper than the ones pre-made
I know i could go actually find out but I am at work, just thought someone might know
Old Feb 1, 2006 | 07:39 AM
Gabriel's Avatar
Originally Posted by Matt@HSW
I believe it's:
Matt
You were right. Everything is working perfectly now, thanks guys. Just need to get the bottle filled
Old Feb 2, 2006 | 09:06 PM
slowpoke96z28's Avatar
theoretically, 0 to 5 volts.
