dfi gen 7 cntrling nitrous?????
Dave
The DFi settings are RPM window, fuel enrichment, timing retard graph, and minimum TPS value.
Its simple, if you run a wet kit just leave fuel enrichment at 0%, set your rpm window, and timing retard graph, and minimum TPS value. Done.
Don't use the window switch, or WOT switch your DFi has it built in already.
Vinny
Vinny
But here is the formula to determine how much the injectors will support:
Flowrate x # of injectors x Duty cycle /BSFC
so 42 x 8 x .8/.5= 537 flywheel hp @ 80% dutycycle
Vinny
