hidden system purge?
Old Feb 13, 2006 | 11:37 AM
wolfy's Avatar
Default hidden system purge?
for those of you that prefer the stealth...where do you guys run your purge? im thinking about going with a hidden system, but not sure where to run the purge at...
-cam
Old Feb 13, 2006 | 11:40 AM
Zeus's Avatar
Some people purge into their wheel wells while doing a burnout. Assuming it's a dry shot, some people do quick purges into their engine if you can figure out a way to cover the noise. Same thing with the exhuast system. Hell if you got medical grade nitrous you could purge into the cockpit and have the funnest race of your life.
Old Feb 13, 2006 | 01:27 PM
1936FordPU's Avatar
i purged mine inside the car at my passenger side feet area..
Old Feb 13, 2006 | 01:32 PM
BAKNBLK's Avatar
I've thought about that to. Since I'm considering a dry kit, I thought about spraying it behind the radiator. Not sure how well the heat of the radiator will mix with the cold nitrous. Might not be a good Idea. I don't know.
Old Feb 13, 2006 | 03:58 PM
Bad Habit Bird's Avatar
that will keep the noise down but it would suck if the purge solenoid stuck open when purging........ It has happened to me before
Old Feb 13, 2006 | 04:01 PM
white2001s10's Avatar
purge into the engine during burn-out. A couple of quick blips does the job.
Old Feb 14, 2006 | 01:17 AM
Nitro Dave's Nitrous Outlet's Avatar
This can also lift ring landings or cause nitrous backfires due to not having the induction to pull the nitrous and fuel in.
Ofcourse easier to do with adry system...
Dave
I suggest purging under the car during the burn out.
Dave
Old Feb 14, 2006 | 07:58 AM
wolfy's Avatar
any suggestions as to where? i dont want to purge somewhere where it would be a bad idea to...
-cam
Old Feb 14, 2006 | 08:06 AM
N2O is non-flamable so about anywhere is fair game.
I would've thought backfires were desirable given the popularity of wet systems. They make for great track video
Old Feb 14, 2006 | 08:31 AM
1936FordPU's Avatar
Thats when you reach behind the seat and move the laundry basket to cut the bottle off....DUH!!! People do think of things happening when stuf fis getting setup.
Old Feb 14, 2006 | 08:46 AM
If it's going to stick, I'd rather it happen during purge rather than down-track.
Old Feb 14, 2006 | 09:14 AM
NitrousDirect's Avatar
how about a fitting into your exhaust?
Old Feb 14, 2006 | 11:02 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
We have done this before...We purge into a frame Rail/Type location.. No noise and no plume to see On a vette we do the torque tube tunnel... Use a small line....
Old Feb 14, 2006 | 08:02 PM
Dragframe's Avatar
Dave
Dave
well i would assume if you purge into the motor you will purge before the MAF...then the motor wouldn't lean out nad your good to go.. would work fine with a wet system too.... jsut as long as the line from the purge valve goes before the MAF
