NX rail tech question
Phil
I guess I am going to have to measure... You will also need a mill, you have to offset the tapped holes center lines farther apart than the current thou rail holes. A drill will not cut it. The large hole or tapped hole will need to be set up so the most outer part of your tapped hole rides the edge of .187 rail throu hole. It is not done for 2 reasons, Time and it is a pain in the ***. lol
Ricky
