Single plane Nitrous plate? (Nitrous Sponsors)
Which one of the vendors is the one making a nitrous plate for the single plane intake which basically will direct the nitrous and fuel into each intake runner. There are no spray bars going through the middle (open area) of the plate. All the holes are around the perimeter . I had seen some pics somewhere of this in its developemental stages.
Very interested in this particular plate system. Any info is appreciated , Thanks.
Closed ex-Sponsor Account
Look for one of NEXT's threads, it the Gemini Twin Plate from NX. 50-300 100-500 you can pick which one you want. The plate works beautifully on that intake.
60040-10 50-300hp
60540-10 100-500hp
Ricky
60040-10 50-300hp
60540-10 100-500hp
Ricky
Oh yea , thats right it was Next that was working on this. Thanks alot for your reply .
60040-10 50-300hp
60540-10 100-500hp
Ricky
60040-10 50-300hp
60540-10 100-500hp
Ricky
Yes and the part numbers are listed by Ricky above. The plate system is their standard off the shelf unit.
My post might have been a little misleading by saying it was part of the mock up. I just had Ricky doing some custom work for my second stage kit.
Have you monitored the EGT's in each cylinder to see exactly how even the mixture distribution is in each cylinder?
Originally Posted by next
Rob,
Here was the first mock up Ricky did on my intake that shows just a single plate with the perimeter spray pattern that is directional to each runner.
Curious to see how the distribution is with this multi port design is VS a plate with bars.
My process will be reading the plugs for individual cylinder activity.
