what timming on a 125-150 shot
couple of degrees pulled for safety in my .02
Hawk
To compare tables visit H.P. or Red Hard Supra's Blogs or e-mail me i can send.
Hawk
But you can pull timing with a simple IAT Tricker! Look to Robert's site for details on timing.
Hawk
Alot of site's can be accessed from the stickies!
H.P.Tuners and Supra both have links.
Hawk
Robert
Robert
was 650.00. Yes i still need to pay Dyno time but just for bases. And the programing
i load.
Hawk
On a side note getting a tunning program and a used laptop is cheaper in the long run not to mention if you know a few people who want tunning done you can split the cost. 300 for laptop on ebay + 650 for 2 modle years with hptunners and wide band interface (new) +200 for wide band= 1150 can be split between 2 people
Now 2 dyno tunes for 2 people = 2000
Robert
Edit: 98redorange, likely with your set-up stock value max timing should be fine. Really the only way to tune for peak power, concerning timing, is to do it on a dyno. Max timing without KR is not always max HP, so this is were the dyno can help. Some think running timing up till knock then backing it off is the way, not so. What works best for your set-up you'll need to tune for, but a good starting place is stock values. I am running a total of 22* and am set-up for a 200 shot right now. I hope you can gleen some insight from everyones input and get a set value that works for you.
