OK back to the dry problems
If the MAF is de-screened and working correctly with a stock PCM calibration, and you still go lean then you pretty much have to have a fuel delivery problem related to injector DC, or fuel pressure.
Otherwise it could be from a non-stock calibration, in which case you take it back to your tuner, because none of us here have any clue what all is done in the calibration.
I have burnt plugs on 5 different runs it was always 3 plugs not always the same plugs but always the front two cylinders on either side never cylinder 5,6,7,8 and witch it has never happened on the wet kit this has happened on TR-6 and 8's evrytime it has been back to the tunner it was blamed on the location of the nozzel but know matter where we have put it same story, the last time i ran the car i descreened the MAF and it was better but i will not run my N20 at 13+ afr I am 100% sure that i do not have a fuel delivery problem But anyways Thank you for all your help but I can see its just not worth it for me to run a dry kit I am not a tunner and dont have time to be one right now I will be putting on a direct port so I can turn up the wet and ditch the dry
Thanks.......Greg
I have been running a wet kit for over 15years My car has a stand alone fuel system and i have been able to tune it at 11.8 flat with 0 problems I want to run a total of 300hp 200 wet 100dry and with out a direct port i care not to run 300hp of fuel through my ls6 intake.
And as far as question my self My car is a DD 3540 pounds NO driver has a 383 allstroke that was built by me a 4l60e also built by me car gets 14mpg and at the track It 60ft in the 30's on drag radials and has run 6.30 in the 1/8 mile on a 175 wet kit So me not knowing anything a bout a dry tune Does that make me stupid???
Thanks for your help its not that i want to give up I work alot and dont have that much time anymore to spend with the car but i will do as you say I have the new EFI scan and tune and will play with it after hours to figure this out, I will post back later with the results.
come on now. Hes just asking questions here. He is not the tuner on this car and his tuner does not come on LS1tech much. Jeremy Formato did the tuning on this car and Jeremy has done plenty of dry setups...including all of mine. I have sprayed 300 dry on a highly modded tune..as well as many others. So hes not clueless on this issue. And I am sure J Formato has tried a few things to correct the problem. Someting about his combo is making it difficult.
Greg...what MAF are you using? IS it the small stock one? Or do you have a Z06 or truck larger one?
If its the stock MAF...it really does sound like a placement issue. White can attest to the differences in placement. I think they were blasting the MAF wires directly and getting the car to go pig rich and max the duty cyle just using nozzle placement. You may try to relocate again. Getting a bit closer to the MAF and aiming it more at the MAF. I have no idea really how many spots you tried. But it can be an issue. What intake do you have and where is your nozzle?
After looking at the runs on the EFI live you can see the maf and injector duty cycle drop right where i feel it lay down and where the afr peeks in the 13.'s on the last run that i stayed in the gas you can see the maf and injectors go down and then back up, Its like the maf isnt seeing the n20 for a sec at the top of the runs but after seeing the last run it like my bottle is surging but its full and stayed at 1000psi during all the runs.
No spark plugs where burnt and after thinking about it we havent burnt any plugs sence the car was retuned a few weeks ago so maybe that problem was fixed
Robert
Is this a wideband you are looking at for AFR?
I wasnt saying the problem was fixed i just meant the buring of the plugs before jeremy saw the car last it would purn plugs,
The last run it felt like a wet kit with a low bottle it would pull then lay out again and again, I am woundering if its not going lean its just not flowing n20 100% of the time,
The maf on the car now is new with no screen i do have another that has a screen i can descreen it and try
Hawk
I dont think it is fuel related you can watch the maf reading and it will decrease like there is no n20 or it doesnt see it
Robert
Some people re-clock the MAF and get varied results.
I've always sprayed the MAF wires from relatively close range and never had any problems.
There's also the option of running the dry system without the MAF at all, which should eliminate all problems of this sort.
A competent tuner will have no problem doing this.
Robert
Robert
