pinks/nos
BUT, as John (GoldZ) has said, I don't think there has ever been a documented instance where heating a bottle with a torch was the direct result of a bottle explosion. That's definately not to say it's ok, but how bad can it be really? Most of us know that the torch can create weak spots in the aluminum of the bottle, but again, there is not any documented proof that this has caused an explosion. I will say this, I don't use the torch method any more simply because I don't want to be the first documented instance, lol.
On the topic of heat and bottles. I think it would be possible to have a bottle explode from a torch but it would take quite a while because the heat source is too centralized in a small spot. There was a good friend/customer of ours that had his race car burn to the ground a while back and one of his bottles inside the car exploded from the heat. The fire completely engulfed the bottle and I guess heated the entire thing very quickly. The bottle looked like someone had cut it and peeled it open like a tin can, pretty scary looking. So I guess that if you could make the heat from the torch cover more area and get it to heat the bottle quicker, then it could cause an explosion. Who knows?
Beaflag VonRathburg - It cracks me up when people bring up this guy's explosion and try to say that nitrous is dangerous or heating bottles is dangerous or whatever else they like to say when this guy is brought up. The truth of the matter is that guy did every single thing you could possibly do wrong when it comes to safely heating a nitrous bottle.
- he doubled up the burst disks which raises their burst rating to a point that is higher than the burst rating of the bottle itself.
- he wired the bottle heater to a constant power source instead of to a switched power source. When he turned the car off, the heater continued to have power to it.
- he was heating the bottle with the bottle valve shut. This took the pressure cut-off switch out of the equation, so the heater would continue to heat indefinately.
- he left the heater on when he parked the car in his garage and went inside his house, not giving a second thought to the heater being on.
That explosion was caused by nothing more than a single persons absolute stupidity concerning nitrous safety, period. It had nothing to do with the heater, nitrous system, nitrous product, or product failure.
Sorry if that came across wrong, but it really irritates me when people bring that guy up trying to give nitrous a negative image (nitrous doesn't need any help in that department, lol), and most of the time the people bringing it up have no idea of the rest of that story.
. I totally agree with you. I'm not trying to say nitrous is dangerous or anything like that, once I get some $ I'm gonna hit the spray too. All I was trying to show was an example of a bottle exploding and what sort of damage it could do. The people racing have no idea who they are racing or what they are racing until they start taping. That is except the Bike race between Slowe and Miller and they raced heads up the whole time.
its called natural selection.
The pressure disk would burst if the pressure got too high, but the theory behind heating a bottle with a torch is that it weakens the bottle. The weakened bottle would explode at pressures LESS than what would cause the disk to blow....
