250 to much on stock internals?
Why not 100 unleaded?
VSGLS1: everything above 104 is pretty much leaded. With 117 leaded in a standalone I imagine you could still get some pretty good milage out of the O2 sensors since your not using it very often. And from what I'm told, there are lead tollerant O2s on the market. If you went 100 unleaded in the standalone the overal octane rating would obviously not be as high as with say the 93/117, might be enough depending on teh set up though. With my 225 shot I've been running a 50/50 93/104 (unleaded) mix in the tank. It's a pain in the *** to having to deal with the mix in the factory tank and it's getting expensive to drive back and forth to the track paying $2.70 for 93 and $7.00 for 104 (usually need 10 gallons total to go play for the night). I'd rather just put 93 in the tank and a gallon of 117 NOS in the standalone, will save me over $15 in gas per trip and I should be able to put alittle more timing back in the car. The standalone will also cure the fueling problems that I'm having.
Dan
