help with wiring diagram.
Old Apr 8, 2006 | 05:56 PM
jocko's Avatar
Default help with wiring diagram.
kit is going in a 6 speed 00 vette,i'm using a digital window switch from msd with a dynotune wet kit along with the arming switch and a hand activated switch wich use to be a trans brake switch,i know i should of gone with the tps/window switch but is too late now.
Old Apr 8, 2006 | 06:04 PM
NOSjohn's Avatar
Restricted User
Dynotune didn't have instructions included? I think their site may outline a setup and varying setups for instances such as these. If not, check with Robert56 or NXRicky on this forum section - Nitrous. So many nitrous vendors I forget who deals in what.
Old Apr 8, 2006 | 06:25 PM
Beer99C5's Avatar
If you have not recieved your kit yet, or you did not get your instructions, PM Dean or Dan at Dynotune, they will email you what you need.
For the linelock I think Hurst has those instructions availible online.
Old Apr 8, 2006 | 07:32 PM
jocko's Avatar
the instructions in the kit are not for wiring in of the window switch and the ones with the window switch are to use the window switch by itself without a switch i think,i messed up is not a line lock switch is a trans brake switch that i use to activate the nitrous after arming it.
Old Apr 8, 2006 | 08:20 PM
Beer99C5's Avatar
Whoops posted this in the other thread, shoulda been here sorry...
OK when it comes to wiring...Do a search for NXRicky and whatever it is your trying to wire...in this case MSD...
https://ls1tech.com/forums/showthrea...&highlight=MSD
Hope that helps?
Old Apr 9, 2006 | 05:48 PM
jocko's Avatar
got it all working,thanks to those that tried to help.
