Sprayed for the first time using fuel from the stand alone. WOW!
Old Apr 9, 2006 | 11:58 AM
SmaknaSS's Avatar
Default Sprayed for the first time using fuel from the stand alone. WOW!
I dont know if it's just me or not but spraying nitrous and using fuel from my stand alone seem's to hit much harder than before. My AFR way richer this time to about11.3~11.6 AFR from 12.7~11.9 AFR from before. I guess I need to get back on the dyno to find out where my power is really at. BTW my FJO is set the same as before: I'm spraying from 20% to 100% in a 1 sec ramp time.
Old Apr 9, 2006 | 12:39 PM
CAT3's Avatar
Restricted User
What size shot and type kit ( I see NX, but single nozzle or what)?
Old Apr 9, 2006 | 12:46 PM
SmaknaSS's Avatar
Dual shark nozzle NX kit and only 100HP Shot to keep it safe for now.
Old Apr 9, 2006 | 12:48 PM
CAT3's Avatar
Restricted User
Running 50shot each side? Low pressure fueling? Richen it up before you go much bigger.
Old Apr 9, 2006 | 12:51 PM
SmaknaSS's Avatar
yes, a 50HP shot each side and high pressure fueling (60 PSI) for now.
Old Apr 10, 2006 | 09:49 PM
BadAssFast's Avatar
What kind of fuel pressure are you running high or low?
Old Apr 10, 2006 | 10:03 PM
brad8266's Avatar
high see above post. 60 psi
