Purge into an exhaust pipe
hiding it is one thing, covering up the noise is another. mine is Very loud, but maybe if you purge during a burnout it might help. I wonder how flammable it would be back their in the exhaust?
Are you runnin a hand held button or a micro switch on the pedal? Most of the time I just purge mine through the motor in the burn out box, if you have hand held button. Most people will never even know!
seriously though, if your gonna do it make sure its after the cat, otherwise when the fuel in the exhaust goes through the cat it will have enough oxygen to explode, my thoughts.
Just run the line from the solenoid down into the engine bay so it purges underneath the car or into one of the fenders. You shouldn't be able to see it while doing a burnout, or at all for that matter.
8 second mod
i dont even run a line off my purge. i just let it go under the hood, you can hear it, but the burnout idea would work!!
i might run lines this year, just so i can be sure both purge's work
8 second mod
Originally Posted by TRMIN8R
I don't even use a purge anymore. Just for show IMO. I just "purge" the nitrous and fuel at the same time through the motor.
it has a big effect on your tune up.
to much psi, and boom, to low, and you wash down the motor.
purge makes a big deal.
i dont purge outside just for that reason, and i got rid of my master blaster and went with a basic one just so it was hard to hear. but on big wet shots, its good for tunning, and consistancy
8 second mod
Originally Posted by Flyer
Should the fuel be purged as well???
8 second mod
Originally Posted by 87Lt1Monte
Last time i checked on the side of my bottle its a non flammable gas? how could it "catch fire" .. I would really like to know.
Tenured Member
Just do the motor purge in the burnout box. When you do your burnout and your just about ready to get off the brakes and start rolling foward for the "Grab" feeling. Thats when you can hit it for a second.
i have seen setups into the rear wheel wells, and purge during burnouts. i don't see the point of hiding the purge, it doesn't have to be showy, but just do it under the car or something
Purging into the exhaust is fine. Nitrous needs to be compressed and heated to release the oxygen. Nothing will happen.
Rather than waste it though, you could blow it onto your solenoids which will help cool them down and give you a more consistent hit. I've also seen people run an insulating sleeve over the nitrous feed line, then purge down into the sleeve to cool the line.
Jim
Jim
