help!!!!
Old Apr 10, 2006 | 09:52 PM
1MEANGTO's Avatar
Default help!!!!
has anybody gotten something loose after using lock-tite???? ive tried everything nothing will loosen, any suggestion??
Old Apr 10, 2006 | 10:01 PM
383LQ4SS's Avatar
heat...either a torch...or a very good heat gun
Old Apr 10, 2006 | 10:02 PM
brad8266's Avatar
LOL, use the force!!! What are you trying to remove??
Old Apr 10, 2006 | 10:06 PM
1MEANGTO's Avatar
fuel selanoid!!!!! ahhaha
Old Apr 10, 2006 | 10:11 PM
brad8266's Avatar
heat. Damn you cant just force it to loosen??
Old Apr 10, 2006 | 10:15 PM
1MEANGTO's Avatar
ive been trying to for like 20 min. and im not exactly weak either, dont know
Old Apr 10, 2006 | 10:22 PM
terry s's Avatar
Make sure you are using a good 6-point socket or wrench to keep from rounding off the corners on the fitting. Heat will help but call the manufacurer first as too much might damage the solenoid.
Next time use medium strength locktite (blue), and it only takes a little. It sounds like you used a bunch of (red) stud & bearing mount locktite. That type says on the bottle you need to use heat to remove it. But if you don't use too much it will sometimes come loose without heat.
Old Apr 10, 2006 | 10:35 PM
1MEANGTO's Avatar
its off finally!!
