Is 150 shot safe on stock shortblock
Old Apr 18, 2006 | 12:25 PM
j88l98irocz's Avatar
Default Is 150 shot safe on stock shortblock
Hi guys, I have a 2000 camaro ss m6 I have decided to run nitrous. the car allready has the patroit stage 2 ls6 heads, cam, intake, slp longtubes,ported tb,pullys and the coolant bypass. stock bottom end and stock 3.42's the car dynoed 422 hp to the rear wheels. how high of a horse power shot can i run ? any advice would be greatly appreciated thanks John.
also if i would run a 150 shot do i need a bigger fuel pump/injectors ?
Old Apr 18, 2006 | 12:37 PM
98redorangeta's Avatar
Yeah if you have the standard saftey features and get a new fuel pump you will be fine on stock short block.
Old Apr 19, 2006 | 04:18 PM
1FSTZ71's Avatar
I've seen 200 kits on factory engines (my friend Todd has over 128K on his). He runs 11.60's with a converter, tires and a 200 kit lol
Old Apr 19, 2006 | 07:09 PM
SmaknaSS's Avatar
I believe he means H/C and 150 shot of nitrous.
Old Apr 19, 2006 | 07:14 PM
SmaknaSS's Avatar
Wet or dry, if dry then you WILL need bigger injectors and fuel pump.
Old Apr 20, 2006 | 11:43 AM
Z2K_MrJ's Avatar
Board Certified Idiot
All your current Bolt ons along with H/C pack.. I would Be scarce about tossing a 150 wet shot on there.Using your stock Bottem END. You would need a vry Good TUne prolly have to make it a Dual stage not a single 150. For your Bottem End to stay alive for a little bit. Personally i would not reccomend trying to have 600Hp on a stock bottemEnd. It has KAABOOM Written all over it LOL
Old Apr 20, 2006 | 11:57 AM
mpe488's Avatar
I wouldn't do it either, but many people have done so successfully, TRMIN8R for one.
Old Apr 20, 2006 | 12:37 PM
WOT's Avatar
WOT
100, 150, 180 and then some on a stock bottom end in my old TA. Never had a problem. This was with all the bolt ons with a head cam to boot. It can be done. Just don't have some joe schmoe tune your car. Take it a little more at a time. Remember to check your plugs often, and run the occassional compression check to see if things are starting to slide.
Old Apr 20, 2006 | 02:52 PM
TurboB13's Avatar
he's not heads/cam. he is also at elevation.
TurboB13's Avatar
gay, stupid double post
Old Apr 20, 2006 | 05:39 PM
SmaknaSS's Avatar
We all know better. just admit it, 10 post and your already a post *****.
