Nitrous Related Wiring
Old Feb 12, 2022 | 09:44 AM
  #321
5.7stroker's Avatar
Originally Posted by SatisTraction
I’ve searched and I’m sure that I have missed it.
i need a diagram for the following
nitrous outlet 90mm plate kit on a 2006 5.3 truck
lnc2000 retard and timing
winmax window switch
line lock.
i do have the nitrous outlet switch panel. I have the heater, purge, and opener wired up.
thanks
Just look at the diagram here for the window switch: https://nitrousoutlet.com/files/inst...witch-v1-1.pdf
And essentially replace the nitrous mini in this diagram with the window switch above: https://cimg9.ibsrv.net/gimg/ls1tech...30aff532d2.jpg
Then just find a diagram of your ECM and locate the tach signal wire and the TPS wire. Not sure if this is your ecm or not: https://www.performancetrucks.net/fo...verado-430819/
Old Feb 12, 2022 | 10:13 AM
  #322
SatisTraction's Avatar
it looks like the NOS mini provided the ground for the solenoids. Dont think the Winmax works that way. I’ve been studying on these but I’m a little over my head 😂
Old Feb 12, 2022 | 10:26 AM
  #323
5.7stroker's Avatar
Yes they are grounded at CH1 on the NOS mini. You hook the ground from both solenoids to the blue wire on the Winmax. You hook the power from both solenoids to pin 87 on the relay.
From the link I provided: Blue: Stage 1 Control Output- Connect to the ground side of your relay or solenoid driver for Stage 1.
Old Feb 12, 2022 | 10:49 AM
  #324
so pretty much just like this? I was trying to place this in the spot of the WOT switch on the lnc diagram.
Trying to mix these two diagrams
Lnc
Old Feb 13, 2022 | 09:09 AM
  #325
5.7stroker's Avatar
Here you go. I would run this diagram by N2O outlet on Monday to verify that it's correct:
Old Feb 14, 2022 | 09:46 AM
  #326
thanks for all the help. I’m trying to get a one button set up to hold the line lock and two step while depressed. Once the button is released the the window switch to control the nitrous. The best I can figure is two buttons like this. I think it is basically the same as above. The 12v key should be from the arming switch
Old Feb 14, 2022 | 12:17 PM
  #327
I’m working with NO and think I have the one button wiring worked out. Please look it over
thanks
