Nitrous Related Wiring
Old Jan 23, 2008 | 09:17 PM
  #121
a-mean-89-iroc's Avatar
Hey guys i need a diagram for a carb'd engine. I have a wet kit. I really just need to know how to wire it up right with the WOT switch. Thanks!
Old Jan 23, 2008 | 10:35 PM
  #122
Ray@Nitrous Outlet
Guest
Posts: n/a
carb and efi will wire the same.....any of the diagrams will work.
Old Feb 6, 2008 | 05:03 PM
  #123
Bill Bowling's Avatar
Where does everyone get their 12 v switched and 12 v battery from the inside of the car?
Bill
Old Feb 18, 2008 | 05:58 PM
  #124
FASTFATBOY's Avatar
Hey guys I need a diagram for....
Nos Single stage big shot plate
FPSS
microswitch activation on button
Accel 300+ with the 375+ retard box(12 volt retard activation)
Stand alone fuel system.
Thanks
Old Feb 28, 2008 | 10:20 AM
  #125
Ray@Nitrous Outlet
Guest
Posts: n/a
Single stage with NX TPAS, Nitrous Outlet 4 dial progressive, and MSD window switch
Old Feb 28, 2008 | 10:23 AM
  #126
Ray@Nitrous Outlet
Guest
Posts: n/a
FPSS
Thanks
the fuel systems relay should connect pin 86 to the ACC pin from the master arm switch
Old Mar 7, 2008 | 07:48 PM
  #127
1BADAIR's Avatar
Does anyone have a link for
2 stage nx kit with tps, fpss, timing tuner for the first stage and a window switch controlled second stage(only with first stage on of coarse)
I had it but lost my printout
Old Mar 23, 2008 | 10:53 PM
  #128
matt94z's Avatar
Ayonne have a diagram for a Nitrous Outlet LT1 plate kit with a fpss, purge,and NOS mini controller? Thanks in advance.
Old Mar 24, 2008 | 10:38 AM
  #129
Ray@Nitrous Outlet
Guest
Posts: n/a
Old Mar 26, 2008 | 11:31 PM
  #130
Captain InsaneO's Avatar
Originally Posted by CAT3
Courtesy NX Ricky
Is there any way to get this again? I guess it's been deleted.
Old Mar 26, 2008 | 11:38 PM
  #131
waterbug1999's Avatar
You see the post above ya? Click on Ray's fquick and see if its in there. I believe someone moved them somewhere else.
Old Mar 26, 2008 | 11:40 PM
  #132
I guess I need to make an account up to see them..
Old Mar 26, 2008 | 11:43 PM
  #133
Nope, it's not there.
Old Mar 26, 2008 | 11:45 PM
  #134
Sorry... just thought it might.
Old Mar 28, 2008 | 02:53 PM
  #135
JoeMama's GTO's Avatar
Has anyone wired up their noids in series so that they both have to open or is there not enough voltage?
Old Mar 29, 2008 | 01:37 AM
  #136
Actually what I am looking for is the NX Single Stage w/ Mallory WS. I have the old style WS. The wires are: 2 orange 1 black 1 red 1 green 2 purple (not used).
From what I can see the black is of course a ground, red is hot, green goes to the tach wire, one orange to the on/off button, and the other orange goes to the red wire off the relay. It looks pretty simple, but for some reason I keep thinking... it wasn't.
Old Mar 30, 2008 | 08:40 PM
  #137
datsbad's Avatar
Looking for transbrake, 2 step and NOS switch wiring.
transbrake activated and 2 step at once, NOS shut down till transbrake/2 step button is released.
Thanks
Old Apr 2, 2008 | 04:09 PM
  #138
Ray@Nitrous Outlet
Guest
Posts: n/a
Thanks
its in this thread or in the link in my sig
Old Apr 2, 2008 | 09:50 PM
  #139
datsbad's Avatar
I dont see it.
Old Apr 3, 2008 | 11:12 AM
  #140
Ray@Nitrous Outlet
Guest
Posts: n/a
I dont see it.
https://ls1tech.com/forums/showpost....&postcount=135
