Nitrous Related Wiring
This is what I came up with:
Thanks again Ray!!!
Nitrous Outlet 90 mm plate system
3 button ashtray panel (purge, heater, arm switch)
Nitrous Outlet dual digital window switch
FPSS
No WOT
Thank you
follow the diagram that came with the window switch.....the switch shown will be the activation switch in the switch panel....the FPSS goes inline inbetween the window switch and pin 85 of the relay
Ground --> FPSS --> WOT Switch --> MSD 8969 --> HSW Interface --> N20 Relay
Is that too many components on the ground side, even with a 12-14 ga wire? Am I better off wiring the WOT Switch into the hot side between the N20 arming switch and relay?
Just trying to get my ducks in a row...
-Allen
I've included everything that I need except the HSW Interface wiring. I'm not sure what's entailed there, so I just made it a simple in/out. Also, the warmer is the 860 mount/heater, so there's a pressure switch involved too, but I figured I didn't need to put that in the diagram.
Could someone look over this and see what they think? Any obvious problems?
Thanks,
Allen
Thanks,
Allen
i have a dynotune digital window switch, heater, and a FPSS
its will be same wire blue for tps or wot and green for tech ?!
ithink tech wire is white and tps is green iget them from corvette
not sure on the exact wire colors on the G8.
but I do know it has the same coil pack plug on the pass side as the picture Beer99c5 posted earlier in this thread, and will have the same rising/falling TPS signal, that can be tested with a volt meter....you need a 0-5v variable voltage TPS reference wire
