Nitrous Related Wiring
Old Dec 23, 2008 | 05:27 PM
  #181
Grant@NitroDaves's Avatar
LS1TECH Sponsor
Wiring diagram for using Nitrous Outlet Window Switch with ZEX box.
Old Dec 26, 2008 | 11:58 PM
  #182
SStud's Avatar
Can someone help me out please. if anyone wants to know, ive already searched high and low, some stuff comes close but nothing spot on.
ls1 f body.
nx wet kit single stage, nitro daves digital dual stage window, purge, nx bottle warmer, nx bottle opener.
i also have a question, i bought the hsw 4 button switch plate, but i think i just realized i cant use just 1 switch for the bottle opener, i have to use 2 switches to get it to open and close.
if anyone can help that would be great thanks.
Old Jan 7, 2009 | 11:13 PM
  #183
chetmo's Avatar
Originally Posted by Ray@Nitrous Outlet
the fuel systems relay should connect pin 86 to the ACC pin from the master arm switch
Im running my tps through the n20 outlet window switch, so would I just run the wire from the relay to the switch. Also where it shows wire to ignition crane module, would I just hook these to an acc. or constant.
Old Jan 14, 2009 | 12:33 AM
  #184
Wannabsscamaro's Avatar
tnt f2 power ring....msd window switch....wot switch anyone got a diagram?? Please
Old Feb 6, 2009 | 12:06 AM
  #185
Danger731's Avatar
I need a good clear wiring diagram for a NX bottle opener. Also does it have to be on a 3 way toggle switch ? Can I some how hook it up to 2 basic (on/off) switches ?
Old Feb 8, 2009 | 02:21 PM
  #186
Danger731's Avatar
no one ?
Old Feb 15, 2009 | 07:55 PM
  #187
Air's Avatar
Air
Im not sure if it has been posted, i read through this thread and didnt really see it.
I have a nitrous outlet box i am trying to wire in. All i have left are the green and blue wires, which go to the tach and TPS. I see where there are reverences for a vette and a 04 gto to set this up, but how about for a 98 firebird?
My tps is on the other side of the TB as the vette in the picture. Is it still the blue wire in that connector i need to tap?
I found the connecter on the pass side valve cover that goes to the coil packs. Is it still a light greenish wire for the tach signal?
im not really sure how to "search" for this eleswhere, so any help is appreciated.
Old Feb 19, 2009 | 02:45 PM
  #188
86MonteSS's Avatar
I need a schematic for a dynotune wet kit with an MSD window switch please.
Old Feb 25, 2009 | 10:07 PM
  #189
IROC-Z28_CAMARO's Avatar
How do you wire a dynotune tps activated wot switch.
I have a hsw wet kit, Mallory 685 with window switch and timing retard, Purge, fpss.
Thanks
Old Mar 8, 2009 | 12:15 PM
  #190
bowtiebubba1's Avatar
Default Wiring help
Im from Missouri so i need something to show me how to wire this system.
NX 1 pc. maf system for a C5 corvette.
FJO mini prog. controller.
FPSS
Purge
Arm & purge switch.
I have the system installed but the wiring, im lost.
Old Mar 10, 2009 | 08:08 AM
  #191
Helloooooo
Old Mar 16, 2009 | 07:19 AM
  #192
Nasti98Z's Avatar
I have seen this asked a few times before, I just cannot believe nobody has this diagram, I have tried numorus times to get a phone # for Harlin, nobody seems to have it. I dont think Harlin even exist's anymore, But I will ask this again:
"I have my N20 on a relay w/WOT switch, I have the Harlin wired through a relay to the T/brake it is set up for motor only, I want to set it up so the Harlin works with WOT for the spray, (deactivate the N20 while the T/Brake is on) I bought this car this way would any one have a simple diagram to do this." Thanx.
Old Mar 17, 2009 | 08:21 PM
  #193
jmill96Z's Avatar
Originally Posted by 98WsSick
looking for wiring diagram for coil packs to supply to wherever the hell they go on a 1998 trans am ws6
Are you looking for an RPM source? If so, just take it off the PCM?
Old Mar 24, 2009 | 09:05 PM
  #194
blakern's Avatar
Ok guys does this look correct? I have the dynotune RPM window switch, dynotune wet kit, and fpss.
Can anyone tell me the best way to hook up the rpm/tach wire, and the tps wire. With the tps wire I dont need to run and actual WOT switch, correct?
Thanks
Old Mar 28, 2009 | 06:14 PM
  #195
anyone know how to wire the dynotune tps wot switch?
Old Apr 8, 2009 | 02:40 PM
  #196
Kingc8r's Avatar
Does anyone have a diagram for a NOS 78mm Plate kit with a Nos Mini Controller, Purge, switch panel that has Bottle heater, purge, opener switches?
My kit was bought used and doesn't have instructions
Old Apr 8, 2009 | 04:57 PM
  #197
Ray@Nitrous Outlet
Guest
Posts: n/a
There is a link to diagrams in my signature...there should be one for you posted there
Old Apr 9, 2009 | 03:44 PM
  #198
Kingc8r's Avatar
They all have a FPSS, I thought with the mini controller there is no need for one of these?
At least that's what I've been told
Old Apr 9, 2009 | 03:46 PM
  #199
Kingc8r's Avatar
http://www.fquick.com/garages/viewga...wimg&id=120876
http://www.fquick.com/garages/viewga...wimg&id=129394
Here are the only two that I found.
Old Apr 10, 2009 | 09:13 AM
  #200
Ray@Nitrous Outlet
Guest
Posts: n/a
if you don't use a FPSS, run a continuous wire through the FPSS' location in the diagram.
