Nitrous Related Wiring
Going nuts on this one...
Thanks so much in advance
needs help.......
What in the world is the CORRECT way to wire this system??
Each of the below products has their own directions.
I have the WET NOS plate system for my C5 Corvette as shown in link (I am NOT using the WOT gas peddle switch) Using the Dyno Tune Digital RPM Window switch instead.
http://www.holley.com/data/Products/.../199R10361.pdf
Just purchased the DYNO TUNE Digital RPM Window Switch.
I have the related NOS purge solenoid
Also have a Beers ashtray switch panel similar to shown. I am NOT using a bottle heater so that switch will not be used for the moment.
THANK YOU in Advance for the Help!!!!
BOB
needs help.......
BOB
C5 and Z06 Wiring Schematics
Mr. Beers has been kind enough to hook me up with item by item directions for my application, through multiple pm's
Dynotune air fuel nitrous shutdown (window switch)
on / off arm switch
on / off switch for trans brake ( so i dont accidently bump the momentary)
momentary b and m transbrake button
obviously i want to spray of the brake, any help would be great.
there is a MSD with single stage diagram earlier in this post and in the link in my signature.....please let me know if you have any questions
The FPSS will go inline on the gray wire between the Timing Tiner and pin 85 of the relay
The purge will tap into the wire coming off the ACC pin of the master arm switch, then to the button, then to one wire of the purge solenoid. THe other solenoifd wire will go to ground.
The heater will wire up exactly to the diagram that will come with the switch panel.
EDIT:
After browsing around I found this diagram. Is this how the purge is supposed to be wired in my application? https://ls1tech.com/forums/showpost....1&postcount=94
Wow help please......... Tnt nitrous kit, the hsw interface, msd window switch, purge, fpss
