Nitrous Related Wiring
Old Oct 29, 2007 | 02:12 PM
  #101
1BaadGoat's Avatar
Post 2 Stage Wiring
I was looking at doing a 2 stage Nozzle Kit.
My Question is activation. I Purchased a NOS 2 Stage Mini Controller, and a FPSS. I have a 05 A4 GTO. Would I need another FPSS, and a TPS Switch, and how do I go about wiring the System, as I am in no way an electrician? Any help would be greatly appreciated
Old Oct 29, 2007 | 02:55 PM
  #102
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by n2oJOE
any body have a copy of instructions for the timing tuner? i lost mine thanks n2ojoe
http://www.fullthrottletech.com/atta...2&d=1103730053
Old Oct 29, 2007 | 02:58 PM
  #103
Ray@Nitrous Outlet
Guest
Posts: n/a
put you FPSS on the ground to the controller...then a single FPSS will shut the whole system down.
If you bought pn 15974NOS it will control both stages off the same TPS signal...no extra parts needed.
I am running that box if you have any other questions on it.
Old Oct 29, 2007 | 03:01 PM
  #104
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by silverbandit0996
i lost the instructions to my nitro dave window switch. could someone make a diagram to wire up this window switch, a fpss, and WOT, on a wet kit?
\it is posted in this thread somewhere...or just look in the link in my sig
Old Oct 29, 2007 | 03:02 PM
  #105
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by ronnieforrester
just ordered my nitrous outlet tpas/window switch for my 99 vette, im sure the instructions are complete but im just doing some research before i install the kit. the tpas/ws sends ground to the relay for the noids. ill be using a fpss as well, i assume ill just send the ground output from the tpas/ws box to the fpss then back to the relay.
sound right ?
thanks
the FPSS will go inline between the WS and pin 85 on the relay
Old Nov 4, 2007 | 12:32 AM
  #106
AR15 guy's Avatar
Anyone have a diagram for wiring for a standard wet kit with FPSS, msd digital window switch and WOT switch? Arming switch also.
Old Nov 13, 2007 | 04:33 PM
  #107
Ray@Nitrous Outlet
Guest
Posts: n/a
https://ls1tech.com/forums/showpost....&postcount=148
Old Dec 27, 2007 | 09:55 PM
  #108
Ruckus46Gt's Avatar
I'm at work so if its already posted sorry cant see all images. I'm looking for a wire diagram for a typical wet kit with a purge, fpss, and timing tuner. (kit used wot switch). Using the ash tray switch pannel
Old Dec 28, 2007 | 09:18 AM
  #109
Ray@Nitrous Outlet
Guest
Posts: n/a
The FPSS will go inline on the gray wire between the Timing Tiner and pin 85 of the relay
The purge will tap into the wire coming off the ACC pin of the master arm switch, then to the button, then to one wire of the purge solenoid. THe other solenoifd wire will go to ground.
The heater will wire up exactly to the diagram that will come with the switch panel.
Old Dec 28, 2007 | 08:30 PM
  #110
dementia's Avatar
Hey I was looking around on this thread and I'm lost. Is there a diagram that includes wiring for dry nitrous sys (HSW), nitrous outlet ash tray switch panel, dynotune bottle heater, dynotune tps/window switch and the new dynotune a/f safety kill switch and my plx wideband gauge? Is there a diagram w/ everything wired correctly or do I just follow each wiring diagram they'll provide me w/?
Old Jan 6, 2008 | 02:00 AM
  #111
Hennytime's Avatar
did i miss it some where, but your basic wet kit/purge/msd ws diagram? just want to double check some connections
Old Jan 6, 2008 | 02:04 AM
  #112
Ray@Nitrous Outlet
Guest
Posts: n/a
Old Jan 6, 2008 | 05:05 PM
  #113
bguse1983's Avatar
Default nitrous on 99 frc
I can not get your images to show up on my computer. I have a MSD ws, fpss, tps, heater, solenoid...single stage dry system. Can you show me the diagram you used for this pls. thx.....I have a 15835 NOS progressive controller I am trying to get wiring directions for too if you can help me with that as well. thx again.
Old Jan 6, 2008 | 10:18 PM
  #114
Ray@Nitrous Outlet
Guest
Posts: n/a
check out the link in my signature....I have many different one posted on Fquick
Old Jan 13, 2008 | 01:32 PM
  #115
dirt track racer 81's Avatar
need a wiring diagram for a lt1 basic nitrous express kit with a NX window switch and with an NX tps
Old Jan 18, 2008 | 05:15 PM
  #116
Ray@Nitrous Outlet
Guest
Posts: n/a
Old Jan 21, 2008 | 01:56 PM
  #117
Gordata's Avatar
Hello,This is my first post, I am looking for wiring a Zex Wet Kit with FJO Racing Nitrous mini progressiver controller. Searched and didnt find anything.
Old Jan 21, 2008 | 01:59 PM
  #118
Ray@Nitrous Outlet
Guest
Posts: n/a
The ZEX boxes are not compatible with any progressive controller.....their internal electronics do not like to be pulsed.
I can get you a wiring diagram but this will only be reccomended for window switch style operation only. I cannot promise the NMU will work correctly if you pulse the box.
Old Jan 22, 2008 | 10:19 AM
  #119
Gordata's Avatar
Ok So I am not going with the FJO Nitrous Mini Controller, I decided to go with the Zex Window Switch, Could you help me up with a diagram for me that including a dynotune Purge kit.
Old Jan 22, 2008 | 11:18 AM
  #120
Ray@Nitrous Outlet
Guest
Posts: n/a
the window switch will come with a diagram for the 2 ZEX products....the purge will wire the same as this diagram.
https://ls1tech.com/forums/showpost....1&postcount=94
you will tap into the ACC pin from your arm switch..ran to one side of the button. The from the button to one solenoid wire, the other wire will go to ground.
