Nitrous Related Wiring
Old Apr 2, 2014 | 12:00 AM
  #301
3stgstocker's Avatar
anybody have a wiring diagram for single stage plate with lingenfelter 2 step with transbrake and biondo rpm 1 shift box
Old Jun 1, 2014 | 02:15 PM
  #302
jt_2002_ta's Avatar
looking for a diagram for a single stage wet kit,msd digital window switch,lnc 2000 and a purge kit. thanks in advance
Old Dec 23, 2014 | 04:10 AM
  #303
BigRedChvy355's Avatar
I'm needing a diagram for:
NX Plate kit mated to a Lingenfelter RPM-003 RPM Switch
Old Jan 14, 2015 | 01:13 PM
  #304
badformulaLS1's Avatar
Apologies if I missed it in previous pages but if anyone has a schematic of a single stage wet kit with trick nitrous controller, nitrous/fuel/purge solenoids, switch panel, and an LNC-2000 it would be a great help to me.
Also if anyone know of any write ups showing the actual install of a nitrous kit that would be awesome. I can read schematics but have little experience actually applying it to the way things are actually laid out and positioned/located in the vehicle.
Old Jan 24, 2015 | 05:22 PM
  #305
shepss217's Avatar
Default Help please!!
i hate wiring, lol i need help with my setup, i have a single stage with nozzle, ligenfelter LNC-2000 with zex window switch, relay, FPSS and 4 switch panel, thanks to anyone who can help me
Old Jan 27, 2015 | 02:35 PM
  #306
ezzlez28's Avatar
Looking for a diagram if possible:
Nitrous Outlet Single Stage Plate Kit
Heater w/ pressure switch
Purge
FPSS
NOS Mini
Nitrous Outlet ashtray switch panel
I picked up a Leash single stage board, single relay module and fuse block also.
Old May 17, 2017 | 09:04 AM
  #307
fathead7466's Avatar
Default 15974 progressive controller diagram
Looking for wiring for NOS system:
WOT microswitch
Purge
Arming switch
fused link for power
single stage NOS
Relays if needed
No Trans brake
Old Sep 1, 2018 | 12:54 PM
  #308
5.7stroker's Avatar
NOS mini with LNC 2000
NOS mini with timing pulled through traction control and 2002 ECM flash
Diagrams here: https://ls1tech.com/forums/nitrous-o...-see-here.html
Old Dec 8, 2018 | 08:13 AM
  #309
Camar01le's Avatar
Originally Posted by brandon@nitrousoutlet
You're in luck! We just went live with a Wiring Diagram Program!PM me the info on your entire system and I'll let you know what we can do it for!
I know this is an old post, but if I sent you my system could you help with a wiring diagram? Just bought a 92mm Nitrous outlet system and a bunch of extras. Any help would be great!
Old Dec 10, 2018 | 04:11 PM
  #310
brandon@nitrousoutlet's Avatar
Let me know what all you have in the system and I might just have one for you.
Old Dec 10, 2018 | 05:51 PM
  #311
Camar01le's Avatar
Thank you for any help you can provide! Please see below for a list of what I just purchased from WS6store. I know you may not be able to help with the PSN-1 gauge but I put it in there incase you can.
Nitrous Outlet 92mm plate system
" " remote bottle opener
" " ash tray 4 switch panel
" " stage 2 accessory package (bottle heater / purge kit)
Innovate Motorsports PSN-1 gauge for window switch & AFR safety cutout switch
Old Dec 11, 2018 | 03:25 PM
  #312
I know this isnt exactly what you're looking for, but its a solid start!
Old Dec 11, 2018 | 07:41 PM
  #313
Camar01le's Avatar
Thank you for your help!
Old Mar 18, 2019 | 11:57 AM
  #314
micbegz28's Avatar
Looking for how to run a NX Maximizer EZ and NX digital TPS/WOT along with a fuel pressure safety switch.
I have a diagram on for the Maximizer and the TPS/WOT switch together, as well as how to run the safey switch with the kit... but cant figure out how to run it together.
-The instructions for the maximizer to TPS/WOT call for the blue wire of the TPS/WOT to go to the white wire of the relay harness that the maximizer plugs into.
-The instructions for the safety switch call for it to be connected to the white wire of the relay harness that the maximizer plugs into.
I dont think just tapping all the wires together is going to help since i feel they will cancel it out, i would think they would need to be wired in like a series almost but not sure how.
Old Mar 18, 2019 | 12:23 PM
  #315
5.7stroker's Avatar
I removed the safety switch like most others have because it was causing issues.
Old May 10, 2019 | 02:28 PM
  #316
Mike Will's Avatar
Angry Nitrous back fire on a 225
I've change cam sensor crank sensor change plates solenoids..... had it on the dyno ..came off the dump an hit the street an it poped..it took on the dyno at hight rpms.... cant shoot it from home I just need some help
Old Jul 20, 2019 | 07:04 PM
  #317
peterskunk's Avatar
Im installing a Nitrous Express Winmax. I need to know which wire is the one for the tach signal, also the one for TPS signal.
Its a 99 C5 LS1 Drive by wire!
thanks
Old Jul 20, 2019 | 07:57 PM
  #318
03EBZ06's Avatar
Been few years but was dark blue wire near tb
Old Oct 6, 2019 | 09:31 AM
  #319
Db71's Avatar
Default Sorry for bringing back an old thread BUT...
Originally Posted by Beer99C5
(Keywords)
Trick Window switch
Two Stage Window Switch
Nitrous Outlet Window Switch
DynoTune Window Switch
Dyno Tune Window Switch
Edited Sept 2006 and is correct info
Do Not go by quotes dated prior to this edited post
I have been asked a bunch of times...
Here is how Vin @ 860 Performance hooked up my Window Switch
This is for a Electronic Throttle Controlled (ETC) C-5 Corvette
Tach and TPS connection
The tach wire was hooked up to the Coil Pak
TPS wire
STEP 1. TACH set-up
0 0 individual coil packs
STEP 7. TPAS Mode
0 2 = TPS signal
STEP 8. TPS WOT setting
Note: only applies if Step 7 is configured as 02
B.C = WOT voltage
While at IDLE, press switch #2 to read and display the TPS signal. Pop the throttle to open it all the way – the unit
only needs to see WOT for a fraction of a second. Now press switch #1 to save the displayed value. (You do not
have to be at WOT when you press switch #1 to save)
[/QUOTE]
Once your done check the RPM on the window switch by holding button 1 in.
Pictured below is the car at idle 700 RPM.
Rev and compare tach to what the Window Switch is seeing if it does not match change your settings in step 1 until you see what matches your application.[/QUOTE]
I dont see the pictures and I'm trying to figure out which wire at the coil on the passenger head for the tach. Any help is GREATLY appreciated!
Old Feb 12, 2022 | 08:50 AM
  #320
SatisTraction's Avatar
Default In need of a wiring diagram
I’ve searched and I’m sure that I have missed it.
i need a diagram for the following
nitrous outlet 90mm plate kit on a 2006 5.3 truck
lnc2000 retard and timing
winmax window switch
line lock.
i do have the nitrous outlet switch panel. I have the heater, purge, and opener wired up.
thanks
