Nitrous Related Wiring
Old Sep 25, 2007 | 10:36 PM
  #81
HAHA I 1's Avatar
NX wet kit with Nitrous Outlet 4- switch panel, purge, Trick window switch with TPS sensor, FPSS, heater, opener
Can someone give me a hand with that one?
Old Sep 26, 2007 | 10:22 AM
  #82
Ray@Nitrous Outlet
Guest
Posts: n/a
https://ls1tech.com/forums/showpost....5&postcount=96
https://ls1tech.com/forums/showpost....9&postcount=85
https://ls1tech.com/forums/showpost....1&postcount=94
most combinations are posted at this point...if you compare the wiring diagram for the system to the one posted for the window switch there are only 2 wires that tap into the system wiring...the white goes to arming switch and the yellow goes to the ground side of the nitrous relay.
The FPSS goes inline on the yellow wire from the window switch
Old Sep 27, 2007 | 02:11 PM
  #83
billybadd's Avatar
TransBrake & Nitrous (nitrous off/trans brake on) ???
I have a Nitro dave single stage plate kit already installed with purge, fpss, 860 heater, N O dig. window switch, WOT switch.
All Im adding is the t-brake.
thanks.
Old Sep 27, 2007 | 04:25 PM
  #84
Ray@Nitrous Outlet
Guest
Posts: n/a
thanks.
looks like that is one that was lost...so here it is again
Old Sep 27, 2007 | 04:54 PM
  #85
billybadd's Avatar
thank you.
Old Sep 27, 2007 | 08:04 PM
  #86
billybadd's Avatar
So basically all I have to do is move the WOT wire from pin 86 on the relay to 87a, then run one leg from the transbrake solenoid and one leg from the transbrake button to pin 86 on the relay? This will make the WOT switch open until I let go of the transbrake button?
Old Sep 28, 2007 | 11:45 PM
  #87
1SlowHoe's Avatar
Destroyer of Transmissions
Looking for the wiring diagram for a TPS switch. The switch I have came with a TNT wet kit and is about a year old. It is a black plastic box with no writing on it and no instructions. I understand how it works but I cant find the schematic for it. Here's a couple of pics, ignore the black electric tape residue all over the wires. BTW, the yellow wire was hooked up to "85" on my relay, if that helps.
Thanks for the help
Old Oct 2, 2007 | 03:44 PM
  #88
SSPerformance's Avatar
looking for the diagram for a wot, with a t-brake an 2-step witout a delay box
Old Oct 2, 2007 | 04:12 PM
  #89
95 Z28's Avatar
Ughh I wish that diagram of the dry kit with MSD WS and FPSS was still available. If anyone happens to have that one saved or something post it up or send it my way please.
Old Oct 3, 2007 | 04:02 PM
  #90
anyone
Old Oct 7, 2007 | 09:21 PM
  #91
billybadd's Avatar
Is this correct?
Old Oct 8, 2007 | 11:28 AM
  #92
Ray@Nitrous Outlet
Guest
Posts: n/a
Is this correct?
Yes...
Old Oct 8, 2007 | 11:30 AM
  #93
Ray@Nitrous Outlet
Guest
Posts: n/a
Thanks for the help
I would suggest calling TNT directly...I currently don't have one for that box
Old Oct 8, 2007 | 11:34 AM
  #94
Ray@Nitrous Outlet
Guest
Posts: n/a
anyone
this is a few posts above yours...should get you close
https://ls1tech.com/forums/showpost....&postcount=137
Old Oct 8, 2007 | 11:36 AM
  #95
Ray@Nitrous Outlet
Guest
Posts: n/a
Old Oct 8, 2007 | 11:50 AM
  #96
billybadd's Avatar
Yes...
thanks Ray.
Old Oct 9, 2007 | 05:21 PM
  #97
95 Z28's Avatar
Annndd thank you sir very much
Old Oct 24, 2007 | 11:06 AM
  #98
silverbandit0996's Avatar
i lost the instructions to my nitro dave window switch. could someone make a diagram to wire up this window switch, a fpss, and WOT, on a wet kit?
Old Oct 28, 2007 | 02:10 PM
  #99
ronnieforrester's Avatar
just ordered my nitrous outlet tpas/window switch for my 99 vette, im sure the instructions are complete but im just doing some research before i install the kit. the tpas/ws sends ground to the relay for the noids. ill be using a fpss as well, i assume ill just send the ground output from the tpas/ws box to the fpss then back to the relay.
sound right ?
thanks
Old Oct 28, 2007 | 11:48 PM
  #100
n2oJOE's Avatar
any body have a copy of instructions for the timing tuner? i lost mine thanks n2ojoe
