Spark Blowout symptoms
it was doing it in the upper rpm's in 3rd gear and part of 4th. the car seemed to me missing and not making all the power. checked everything and my tr6's even have a green band(good afr). they were gapped.038 for 100 shot.
it wouldnt do it on motor passes just when i used the gas.
Spark really doesn't get blown out. You just get misfires.
Assuming no bad plugs, wires, or coils, then it's simply a fueling issue causing misfires.
Best bet is to get a wideband and take a look.
A little too lean, or way to rich will cause misfires.
Restricted User
Chris, can you go make a little run, trying to make sure it does the little "misfire" then immediately shut off the nitrous, then the car, pull over and pull a plug, take a nice macro digital picture? If so, b/w white and I, sure we will see something of importance. Just dont drive it once you let off the throttle...it washes the plug reading out.
After that, if you can, I would close the gap to .035" and go again. Z06 higher compression and 100shot might want a tighter gap. Just difference in thought.
Charlie
Charlie
i closed the gap up but think it may be fueling. i may be running a little lean without the nitrous as P0171(bank 1 lean) came up while i was making motor only passes. i didnt spray after this popped up just incase. cleared the code and it hasnt showed itself again yet...
ill get my bottle filled as soon as possible sometime this week... started with a 50-75-100 and 2 passes on 100 and car was missing on last nitrous pass.
bank 1 is odd cylinders right? 1357 driver side 2468 passenger... ill check my intake for any leaks to as thats also seems to be a cause for this code. whens your trip to the big isle i want some tuning lol
Originally Posted by CAT3
Bank 1 is drivers side, 2,4,6,8 cylinders. Bank 1 tends to lean before Bank 2 when tapping fuel off the rail (fuel leaves the Bank1 side).
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Dave
Restricted User
If your airbridge is letting unmetered air in from behind the MAF yeah that can cause your lean bank coding. I swapped back to the stock accordian, luckily so, after looking at Lrry93's lid. Larry has the same MTI Clear lid, he used the K&N Bellows and the lid is cracked all around the base cause it wont flex at all.
