HP/Weight calculations?
Old May 16, 2006 | 12:00 AM
NitrousDirect's Avatar
Default HP/Weight calculations?
Anyone know of where i can calculate estimated 1/4 mile times or theoretical HP gains from weight savings?
Old May 16, 2006 | 12:02 AM
calongo_SS's Avatar
Try a google search for horsepower calculator, there's lots of them out there. How accurate, who knows...
Old May 16, 2006 | 12:12 AM
not looking for a hp calculator.. thank you though.. got lots of those
Old May 16, 2006 | 12:21 AM
CAT3's Avatar
Restricted User
Just use the calculator backwards....put in your cars weight as it was raced with ET and MPH, write down the ~HP, then go back using the same ET & MPH change weight to reflect the reduction, and see what the new ~HP readings are, thats the difference or effect of weight reduction (or HP Gain) and then you take that new hp gained, using reduced weight and you can estimate the new ET.
Charlie
calongo_SS's Avatar
Somebody should read a little closer <----
lol
Old May 16, 2006 | 12:32 AM
CAT3's Avatar
Restricted User
From just the minute or two I messed with a calculator, I came up with essentiall 16HP per 100lbs. ( I went in 200 lb increments to calc from 3600, 3400, 3200, then 3000 and was consistent).
Effect is as such, maintain weight as the constant:
POUNDS/MPH/HP
3400 127 544
3200 129 544
3000 132 544
Or if you want to see effect on HP maintaining:
3400 127 544
3400 129 576
3400 131 608
See the trend? Its just a guesstimate.
Old May 16, 2006 | 07:23 AM
Noyzee's Avatar
8 second mod
POUNDS/MPH/HP
3400 127 544
3200 129 544
3000 132 544
3400 127 544
3400 129 576
3400 131 608
your so smart. lol
anyway, thats good to know!
Old May 16, 2006 | 01:32 PM
CAT3's Avatar
Restricted User
More like bored and that was something I was looking at before
Old May 16, 2006 | 01:38 PM
Noyzee's Avatar
8 second mod
Old May 17, 2006 | 09:01 AM
oztrack's Avatar
100lb = 0.1s /1.1mph
Old May 17, 2006 | 03:09 PM
CAT3's Avatar
Restricted User
For time wise, thats about right...
Old May 17, 2006 | 11:23 PM
Robert56's Avatar
I have the hp to weight vs ET equation, however, I can't figure out how to get it posted correctly. It was developed by Chrysler's drag racing program in the 70's. You can find it on page 112 of "How to Install Nitrous Oxide", by Joe Pettitt.
Robert
