Daily Driver Bottle Question
never had an issue, the vett has it in all the time also, but it spends most of the week in the garage.
my bottles sit in my trailer 24/7 365 there atleast 5-8 bottles filled all the time, and havent had an issue. you should be ok
-Joel
The temperature in car will rise way over the temp outside if the windows are up, which in turn should heat the bottle about the same as the MBA shift ****. It just like its metal sittin in a oven. This in turn will work like a bottle heater thats been left on. I know some might see that as a little much for a example but its the same idea kinda if you think about it.
I would leave the windows down if your parked @ work & can keep an eye on your car or take the bottle into work with you if possible. Or like stated above leave it at home until it needs to be in the car.
