NX Bottle Question
Old Jun 10, 2006 | 10:46 PM
87Lt1Monte's Avatar
Default NX Bottle Question
Is it a bad idea to use the 2 1/4 inch holes on the sides of these bottles? No one i see actully uses them. I put a guage in one and the bottle heaters pressure sensor in the other.. Should i use a manifold for this? Thanks for the advice in advance.
Old Jun 11, 2006 | 04:30 AM
frknlo's Avatar
Yur talkin 'bout the 2 1/8" ports on the newer nx bottle valves? I did the same and there are no ill effects(except I cant buy the bottle openr from dynotune yet) If anything putting the pressure switch for the bottle heater in that port is the safes place it can be, its constantly references the bottle pressure and that means no worrys if you left the heater on without opening the valve.
Old Jun 11, 2006 | 07:35 AM
87Lt1Monte's Avatar
Yea thats what i was thinking.. Well i guess everything will be ok... Thanks
Old Jun 11, 2006 | 07:41 AM
Beer99C5's Avatar
The 860 Performance (NX Dealer) set up my spare bottle using those ports
I used a manifold on my Street Bottle, it only had one port.
Old Jun 11, 2006 | 08:23 AM
hugger427's Avatar
Hey Beer,
My bottle is set up the same way but i don't have the 90* bend on the pressure guage. What's the part number for that fitting?
Thanks!
Old Jun 11, 2006 | 09:20 AM
Beer99C5's Avatar
I don't have a part number, but here is what it looks like.
Everything is 1/8 NPT I believe.
Old Jun 11, 2006 | 09:54 AM
Somebody09's Avatar
Yeah, as stated, they eliminate the need for all those flow through manifolds. The only "problem" is they still give you a reading when the bottle is closed, which could be very misleading. If you forget to open your bottle it could have quite the adverse effect on your engine with wet shots! I have a tendancy to forget so my gauge doesn't get it's psi reading from the bottle, it gets it from the solenoid area.
Old Jun 13, 2006 | 01:16 PM
goatnipples2002's Avatar
Somebody09 are you saying that you hooked your pressure senor up to the nitrous solenoid so you have the reading from there? If so that is something I never thought of because then you have a more consistent pressure reading.
