someone please explain
can someone please explain the msd window switch... the guy only has 3000 pill which im fine with but the off pill he only has a 6200 off pill. Well that and like 5000 pill.... Does the nitrous automatically stop sprayin at the end pill? like at 5000 rpms will it jus automatically stop spraying..Which pill woudl i be better off using.. because i know sprayin when the rev limiter kicks in is bad? I have a WOT switch too. What if im at wot still? will it still spray or what? Also, will the nitrous always spray at WOT if its on? One more question, im gettin a 3 switch panel. One will purge, one will spray and will one activate? Im actually not even sure if i need 3 switches with the window switch and the WOT switch. One 2 activate and one to purge is all i need i think. Because with the window and the wot switch will i even need to hit the spray button? Thank you mucho to anyone who answers these questions..
The window switch is designed to start & end a function at the RPM of the pills. So, if you have your nitrous armed & your car full throttle, your nitrous will spray from 3000 to 6200 or to whatever off pill you have.
If you are running a nitrous kit and a purge, you only need 2 switches, one to power on the nitrous and one for the purge. Your WOT switch & window switch will "spray" for you.
