New to Nitrous
Old Jun 17, 2006 | 12:34 PM
badtexasZ28's Avatar
Default New to Nitrous
First let me start out by telling you what I have, 2002 Z28 w/6speed, TReX V.2 cam from thunder racing, crane dual valve spring kit w/ Ti retainers, pacesetter LT's w/ true dual exhaust and a whisper lid. I bought a NX EFI kit from a buddy of mine who had to sell it and I am wondering what all I need to do hook it up and make it safe. Also what power level should I cap at?
Thanks in Advance
Old Jun 17, 2006 | 01:38 PM
brad8266's Avatar
You will want a window switch, fuel pressure switch, WOT switch (should come with kit), upgraded fuel pump, NGK TR6 glugs gapped @.038. These are the basics to stay safe. I would start with a 75 shot and if it all works OK switch jets and shoot 150.
Do not try to shortcut by not doing the colder plugs, they are NEEDED. Stock heat range plugs can easily melt with nitrous and this can destroy your engine. Be sure to swap to the colder plugs.
Other good things to have are a bottle heater and remote botrtle opener.
Old Jun 17, 2006 | 01:41 PM
thanks brad
Old Jun 17, 2006 | 08:18 PM
HD1911's Avatar
hey, what happens if i go ahead and buy the TR6 plugs for a future nitrous purchase. Like if i run NA for 6 months or something and never spray and still run those Tr6? will i be losing performance or anything like...lemme know please...thanks
Old Jun 17, 2006 | 09:46 PM
brad8266's Avatar
You can run TR6 plugs NA with no issues at all. I run them and sometimes go a lot of miles without spraying. They always look fine when I finally replace them. You might lose 1-2 HP NA by using TR6's, barely even noticable
Old Jun 17, 2006 | 10:19 PM
HD1911's Avatar
1-2HP....That could mean the difference between a wheelie or not. Thanks brad, i already order the tr55 from summit but i will just send them back and run the TR6's since i plan on using the go fast juice in the near future.
Old Jun 18, 2006 | 02:46 PM
rtr2001ss's Avatar
You can pick up both TR55's and TR6's from Advanced or AutoZone.
Old Jun 18, 2006 | 04:15 PM
brad8266's Avatar
Stock number is 4177 I believe.
Old Jun 18, 2006 | 05:00 PM
Ls1drew's Avatar
i heard these cost only a buck or two for a guy using them, so i went in to buy them and they wanted 9 bucks a plug.
i didnt buy them
Old Jun 18, 2006 | 05:26 PM
rippenhard's Avatar
Buy them from Nitro Outlett...I believe there only a few buck a piece. Dave is the man!!
Old Jun 18, 2006 | 05:40 PM
98 Raptor TA's Avatar
O'reilly auto parts sells em, and they're less than 2 bux a piece
Old Jun 18, 2006 | 06:15 PM
brad8266's Avatar
i didnt buy them
Copper TR6's are less than $2 each, maybe they were giving you the price for irridiums.
Old Jun 19, 2006 | 01:26 PM
NHRATA01's Avatar
While we're talking about noob nitrous questions, I've got one regarding timing. My N/A tune, my timing is only at either 25 or 26 degrees. If I want to add in a 100-125 wet shot over the winter, should I retune with the timing backed off a bit? Or since its fairly low now, is that needed?
Old Jun 19, 2006 | 03:06 PM
brad8266's Avatar
Your timing is OK for that size shot. You can pull some if you want to be super safe, no need to though.
Old Jun 19, 2006 | 04:13 PM
blue01ta's Avatar
Which aftermarket fuel pump?
Old Jun 19, 2006 | 05:52 PM
brad8266's Avatar
Most people like the racetronix kit. It has a walbro 255 pump with a hot wire harness for the pump to ensure it always gets full voltage to the pump. It is extremely reliable for the added fuel needs for nitrous.
Old Jun 19, 2006 | 06:45 PM
speaking of timing, mine is at 28, should i retune my car?
Old Jun 19, 2006 | 08:46 PM
brad8266's Avatar
As long as you arent over a 150 shot and you can run 93 octane you can leave the timing alone. Once again, to be extra safe you can pull a little timing though. I pribably would come down to 26-27
