Nitrous gurus come inside please
Granted, the venturi effect reall only speeds things up (velocity). I wonder why a real venturi is not used in jets, any insight?
Yes bottle pressure will effect the inlet and the outlet pressures but regardless of incoming pressure the larger orifice will still have less of an a to b change. Now the only thing that might screw it up is bottle pressures above 1050 which is where nitrous turns to a gas and loses a lot of density. At 945psi it is 5.44 lb/gal and at 1040 it is 3.78 lb/gal. That is a change of 1.66 lb/gal before that pressure it can range between .30 and .54 lb/gal per 100 psi increase. That much of a density change may have a larger affect. As up to that point the density vs. pressure was much more linear.
Yes, I have found this out the hard way by running at 1150psi, but will be going back to a lower pressure. My goal was running faster with smaller jets on a dry shot, and did ultimately give me my quikest time to date.
Yes you are increasing the volume through the jet by increasing the pressure to it.
Yep, that what I tried/did in above response.
The NOS solenoid you are referring to is the 16010 Super Big Shot. It was a 30amp coil and a .156" orifice. But it was never something that got put into kits and was only really recommended in certain situations. In classes where you were restricted to a certain jet size or to only one nitrous and fuel solenoid.
Yes that's the one. It was capable of flowing over 600hp of nitrous.
And I agree with what was said a few posts up about too much thought being put into a dry kit. Just use a normal solenoid and a mechanical opener. You have to put the bottle somewhere and where ever that is probably has room for an opener on the bottle.
God I love the dry hits. Eventhough mine is very complicated.
