FJO Question
Old Jun 24, 2006 | 10:30 AM
87Lt1Monte's Avatar
Default FJO Question
On the FJO controller how does first gear lockout work? does it sense a drop in rpm and assume that you are in second gear? I dont think it has a trigger wire for a 1st gear lockout ? Thanks in advance for the help.
Old Jun 24, 2006 | 10:50 AM
MEAN LT1's Avatar
Good question. Im interested to know as well.
Old Jun 24, 2006 | 10:55 AM
227Hawk's Avatar
It basically tracks the RPM window settings. Once the turn on and off rpms are accomplished. The proccessor assumes you're in second gear.
Hawk
Old Jun 24, 2006 | 01:02 PM
87Lt1Monte's Avatar
Thanks hawk.. So say i shifted a little early and didnt get to the cut off.. i guess it wouldnt come on then?
Old Jun 24, 2006 | 01:07 PM
Black X's Avatar
Correct you have to complete the window. ie: 3000-6000rpm once then it will activate once your back in the window.
If you short shift and don't exit the window it will not activate. On the other hand if you spin and don't pedal it quick enough you will end up getting nitrous in first gear too.
Hope this helps.
Old Jun 24, 2006 | 01:28 PM
87Lt1Monte's Avatar
If i spinn and jump up and exit the window and hook back up without changing gears thats when i will get the activation in first gear?
Old Jun 24, 2006 | 11:57 PM
Black X's Avatar
exactly
Old Jun 25, 2006 | 11:20 PM
spson04's Avatar
like monte said above, the lockout works simply by allowing you to pass once through your rpm window without activating. when your rpm falls back into the window second time around hang on here it comes. the trigger does not have to be used to accomplish this. you can simply let it rpm based activation. in your program you can use a variety of differnt set ups and even bring it on progressivly if you so desire. kind of a neat feature. if you have any problems shout back or call gerald at fjo, im sure youll find him very informative
