Am I getting a 300 shot?
Old Jul 3, 2006 | 07:33 PM
ls2formula's Avatar
Default Am I getting a 300 shot?
My car ran 10.80@127 on motor.On the next pass I hit with a 300 shot.Went 9.7@141.I have a Nos mini progressive controller.I had it set at 99% which is its highest setting.I also have a timing tuner pulling 12 degrees of timing.My cars race weight is 3500.I have a powerglide,3.73 gears and 28" slicks.I have run the car many times with the same results.My nitrous setup is a direct port with a decaded fuel system.I'm getting 10.8 to 11.0 afr.I have gone down two jet sizes on the fuel.It was 10.0.
thanks
Old Jul 3, 2006 | 07:45 PM
ls2formula's Avatar
One more thing.I have the 4 solenoid kit from Nitro Dave.The mini controller is rated at 40 amps.Dont know if this matters.
Old Jul 4, 2006 | 12:01 AM
Nitro Dave's Nitrous Outlet's Avatar
The air fuel is way to RICH....
Get the airfuel about 11.8. Until then you will not see the performance you are looking for.
Dave
Old Jul 4, 2006 | 07:17 AM
NitrousDirect's Avatar
Dave's right, Congrats on the 9's though.. nice time
Old Jul 4, 2006 | 08:20 AM
theblur98ss's Avatar
Did you spray it on the dyno to see what kind of gains you were getting on the bottle? Nice times though.
Old Jul 4, 2006 | 10:19 AM
ATVracr's Avatar
Dave
11.8 on a 300 shot?
Race gas and some good plugs to match I hope
Old Jul 4, 2006 | 10:58 AM
Cliff's Avatar
300 pills.............I'm thinking you should be in the 8's. Hang on!!!!!!!!!!!!!!!!!!!!
Old Jul 4, 2006 | 11:49 AM
koolrayz's Avatar
do you know how much nitrous your using per pass. you should be using at or over #3 per pass. What size nitrous jet are you using and whats the bottle pressure?
Old Jul 4, 2006 | 12:54 PM
SSwanner's Avatar
it needs to be leaned out a little for sure. i wouldn't worry about the jets, just lower the fuel press on the dedicated system.
how do you like the glide in a "heavy" car?
Old Jul 4, 2006 | 01:28 PM
GrannySShifting's Avatar
the air fuel isnt it I pretty much bet the farm
We pick up almost 20 mph on a 200 shot, soft tune up 10.8-11.0 a/f
Old Jul 4, 2006 | 01:29 PM
ls2formula's Avatar
31 jets on the nitrous
22 jets on the fuel
9 psi on the stand alone
Bottle pressure is between 1000-1100
Race gas in the cell and 3 step colder plugs
no dyno runs on spray
It seems like its only using 2 pounds of nitrous per pass.
love the glide.
I was wondering if I am pulling to much timing?Also wondering if the mini controller can handle the 4 solenoids?
Old Jul 4, 2006 | 01:31 PM
ls2formula's Avatar
This is what I was thinking.Was this an auto or stick?
Old Jul 4, 2006 | 01:45 PM
SSwanner's Avatar
does your car weigh 3500 with you in it or without?
sorry to hi jack your thread, just been having some major tranny problems and a glide is a last resort but my car weighs a lot.
Old Jul 4, 2006 | 01:54 PM
ls2formula's Avatar
Me in it.Car is not a dd.I drive it to the track and to some local meets.
Old Jul 4, 2006 | 02:44 PM
ATVracr's Avatar
TH400.
Old Jul 4, 2006 | 02:51 PM
SSwanner's Avatar
sounds about like mine. did you ever have a 350 or 400 in it? how is the glide compared to either of them?
Old Jul 4, 2006 | 03:08 PM
ls2formula's Avatar
No 350 or 400.I went from 6 gears to two.
Old Jul 4, 2006 | 03:58 PM
SSwanner's Avatar
dayum when i get the 9" in my car its going to get weighed and then i'll further make up my mind. just seems like it would be a dog out of the hole without a hella rear gear ratio. when you switched did you pickup any et/mph?
Old Jul 5, 2006 | 02:05 PM
ls2formula's Avatar
About the same.But its setup more for nitrous now.I never ran the 6 speed with 3.73s.
Old Jul 5, 2006 | 02:37 PM
Hocky's Avatar
Damn... I am only picking up 12-14mph from a 200 shot. How fast are you running? I've attributed my "low" gain to a taller tire and lots more wind resistance due to speed. I am going 124-125 on motor and 136-138 on bottle. I spin a lot of the track, though, so I might be losing mph on that. I am only seeing 105 in the 1/8th.
