Installing a Cold Fusion Wet Kit...
Old Jul 9, 2006 | 12:52 AM
Unstang's Avatar
Question Installing a Cold Fusion Wet Kit...
I am putting a Cold Fusion kit on a '01 Z on Sunday, the kit is brand new. Anything I need to know about ahead of time? I have done a few nitrous installs with NOS, TNT & NX kits. Anything different about the C.F. kits???
Thanks!
Jason
Old Jul 9, 2006 | 07:34 AM
227Hawk's Avatar
The kits are a pretty straight install. GL and let us know about it.
Hawk
Old Jul 9, 2006 | 01:09 PM
Unstang's Avatar
How does the nozzle set up work? I am confused with the metal lines that come with it...
Old Jul 9, 2006 | 02:17 PM
WS6HUMMER's Avatar
Metal lines or steel braided hoses?
Old Jul 9, 2006 | 02:22 PM
flash12t's Avatar
make sure u find a good ground. .!!!!!!!!!!!!!
Old Jul 9, 2006 | 02:28 PM
Unstang's Avatar
He bought a "partial" kit from ebay, it is missing one of the braided lines, so he said C.F. sent him these steel lines to use. I have no idea, but I said I won't do it that way, he needs to get the proper braided line.
Old Jul 9, 2006 | 02:58 PM
WS6HUMMER's Avatar
I couldnt use the 12" braided lines that come with the kit because of where I positioned the nozzle and solenoids so I had to buy 2 18" lines, just a thought for you.
Old Jul 9, 2006 | 06:09 PM
Unstang's Avatar
I messed with it enough for today in my non A/C'd garage, it was 96* here today. I thought I could get the kit on w/ the digital MSD window switch in 4 hours. I am over budget...
Can anyone tell me the layout of the relay? There is a blue wire, a black, grey & dark grey...I am basically done, except for hooking everything to the relay...
Old Jul 9, 2006 | 06:44 PM
WS6HUMMER's Avatar
Maybe this will help you,
I got my kit used so I got no instructions, switches, or relays. The colors you are describing look just like the only relay harness I got with my stuff. The posts on the relay will be numbered just like in the photo I got from the sticky on this forum, stick to that and you'll be safe. Not exact to your setup but you get the point.
Old Jul 9, 2006 | 06:48 PM
Unstang's Avatar
[WS6HUMMER]
Thanks!!!
He is not using a FPSS though...Where does the 85 on the relay go? He is using the MSD digital window switch...Should the yellow wire go to 86 on the relay? I am also not sure what to hook the ACC on the toggle to at this point...
I just did all this a few months ago on my car, but I put the window switch in the glove box, covered all the wires and deleted all of my diagrams.
Old Jul 9, 2006 | 06:58 PM
wyndzer's Avatar
85 is the ground.
WS6HUMMER's Avatar
[WS6HUMMER]
Thanks!!!
He is not using a FPSS though... He is using the MSD digital window switch...Where should the yellow wire to it go?
Is it the yellow wire that gives ground? I thought it was the gray wire, anyway the back of the W/S should tell you which does what. I had one but took it out when I got my timing tuner. Connect whichever wire supplies a ground @ the right RPM to post #85 on the solenoid relay. I would urge him to get A FPSS also, its very cheap peice of mind.
Old Jul 9, 2006 | 07:00 PM
WS6HUMMER's Avatar
Yes I checked It's the Yellow wire on the MSD W/S that goes to post 85.
Old Jul 9, 2006 | 07:02 PM
Unstang's Avatar
Thanks wyndzer & Hummer!!!
ACC on the toggle to the WOT switch sound right?
What will 86 go to???
Old Jul 9, 2006 | 07:58 PM
WS6HUMMER's Avatar
Yeah the Acc wire on the arm switch in the diagram goes to the WOT switch and from there to post 86 of the relay. When you arm the switch the power goes to the WOT switch and when it gets pressed it completes the circut and goes to post 86 energizing the relay.
Old Jul 9, 2006 | 08:50 PM
Unstang's Avatar
Hmmm. On my kit, one of the leads from the WOT is grounded, the other goes to the relay.
Old Jul 10, 2006 | 07:58 AM
WS6HUMMER's Avatar
That will work too as long as that lead coming from the WOT switch is wired to the relay post 85. It's just completing the ground circut.
