street traction with n20
I know with the system armed that if at atraffic light i floor it when it goes green i prob just spin or fish tail.so what is the best way to get traction on the streets with n20?I thought maybe let it roll for alittle bit (normal driving) then floor it when I hit about 20 mph, or isit not possible?Is n20 only good at the track?Can i even use it on the streets?I want to get n20 but not if I can only use it at the track.
Board Certified Idiot
Get a Nice Dual Stage or a Progressive Controller or wait Get Both Spray Your Car from a Light Using that set up on a 150 Shot.. And you will Wet yourself
LCAs will help with some wheel hop. A progressive controller turns the solenoids on and off very fast (pulses the solenoids) to bring the power in gradually, instead of "all at once". They have gotten pretty inexpensive; our Advantage controller is $124.99.
Matt
Matt
I have traction issues on just motor, and I run 315 35 nitto DR's all the time. But beefing up the suspension for better traction helps. The only way my DR's do any good is if I lower the pressure to 18-17 psi and I dont like doing that, feel like I'm gonna mess up my wheels.
i added in a momentary push button switch. the nitrous will come on only when the main on off switch is on, the throttle is wide open(microswitch), and when i push the button down. i dont' use a window switch, but it's probably good safety to have one.
when i stop spinning on motor, i can hit the juice and if i spin on juice i just let on and off of the button untill i stop spinning, then i can keep the button held down.
many ways to do this:
first gear lock out
progressive nitrous controller
my car is weaksauce... it doesnt blow the tires off in second gear. my M/T are sticky as hell when they are hot. ill have to try spraying in first gear and see if they hold.
I have issues with a big stall, spray and nittos from a dig on the street....hoping to fix that issue with some MT et radials...if not, then ill try bfgs...if not then ill spray later...LOL
Progressive controllers are a great way to control your nitrous output to manage traction.
you can view them here
Nitrous Controllers
Nitrous Controllers
