Big Power On The Way
Thanks to Dave for the time on the phone getting this system mapped out.
Thank you for your support. You are going to have one sweet setup. Let me know how you like the system. If you need any tech help we are here to help. Ohh and it has already shiped so you should see it real soon.
Dave
YES SIR I AM.
MY NEW MOTTO
"SPRAY IT UNTIL I RUN OVER THE CRANK"
I want to build an aluminum 402 or warhawk block 450ish engine anyway and these old 6.0L Iron ARE setups are almost worthless from a resale point, so why not see what it will take.
In all seriousness, the new plate system from from Nitro Dave has 5 spray points inside the TB plate, so the distribution/ atomization mixture is great and should flow no problem. I did the dual stage so I can just hit a 100-150 out of the hole and hit another 100 - 150 in second gear so the additional airflow into the engine @ 50+ mph when the 2nd stage hits should help the mixture even more.
Im going to start off easy and only run 1 kit @ 100 - 150 to get a feel for how the cylinders like the juice. Ill read some plugs for a while and go from there. Not that it matters for the question you asked but I also ordered a stand alone pressure regulated fuel system like we talked about the other day @ my house.
If I cant get the airflow / mixture correct for each cylinder like this then I will sipmly add some parts and convert what I have into a 2 stage direct port.
