How many switches needed?
Old Aug 1, 2006 | 06:18 PM
goodrich969's Avatar
Default How many switches needed?
Im running a wet kit on my car, and im curious as to how many switches ill need. I kno atleast two. One to arm the noids and one to purge. My question is, will I need a switch to arm the purge solenoid or will that arm with the fuel and nitrous solenoids? One more quick question, i have a standard NOS brand purge kit, the hard line is only about 6-7 inches long, what should I get to replace it so i can purge throught my hood? Thanks
Old Aug 1, 2006 | 06:22 PM
Beer99C5's Avatar
For switches usually all you need is:
ARM, Heater, and a Purge
a Fourth switch would be an opener if you wanted one.
More switches would be Line Lock, or an additional stage.
Purge is wired as its own, and not dependant on the ARMing of the system, it is usually a push button momentary switch. Heater and Arm are usually toggle or rocker switches.
Old Aug 1, 2006 | 06:40 PM
I currently dont have a heater, so im looking at only two switches
Old Aug 1, 2006 | 06:41 PM
One more question, on my nitrous noids the wires are cut short.. Will 18 gauge wire be a good size?
Old Aug 1, 2006 | 06:48 PM
Beer99C5's Avatar
I recommend a heater, as depending on the temperature outside, you will be shooting 600 PSI on a full bottle vice the recommended 950-1000 without it in the colder season.
A heater will help you get the most out of your system as well as aid in consistancy if your playing at the track.
Old Aug 1, 2006 | 07:09 PM
On my nitrous noids the wires are cut short.. Will 18 gauge wire be a good size?
Old Aug 1, 2006 | 07:14 PM
Beer99C5's Avatar
I would use the same size that is on the Noids, (16 or 14?). You are only talking what 10' of wire? Don't skimp on the 18 Gauge to the noids. 18 is ok for from the switches to the relays.
Old Aug 1, 2006 | 07:25 PM
Do you know weather it is 14 or 16 gauge wire.
Old Aug 2, 2006 | 03:23 AM
227Hawk's Avatar
Beers giving some great info on the Bottle heater. Even if you preheat your bottles before running they drop pressure quickly.
Hawk
Old Aug 2, 2006 | 03:54 AM
Any insight, Thanks so far.
Old Aug 2, 2006 | 04:00 AM
227Hawk's Avatar
Steel braid works nicely, you can pick up lines off Ebay cheaply. And also purge blocks.
Hawk
Old Aug 2, 2006 | 09:47 AM
steel brainded lines? what would i get to make the cloud come out of my hood? Like what would i put on the end?
