Weird hissing.
Old Aug 3, 2006 | 01:01 PM
goodrich969's Avatar
Default Weird hissing.
I opened my bottle jus to see if everything was copasetic. I turned the bottle on a bit and I heard a weird hissing noise coming right before the purge solenoid. I believe it was coming from were the main feed line meets the purge noid. I know its tight enough because i was cranking on it. Would teflon paste do away with the hissing or what? Thanks
Old Aug 3, 2006 | 01:36 PM
TNTramair's Avatar
yes...you should use teflon paste on all the fittings to ensure proper seal. goodluck.
Old Aug 3, 2006 | 01:45 PM
383LQ4SS's Avatar
is it leaking from pipe thread or flared?
If its pipe definately use the teflon past or the thread sealer. be sure to let it dry for a bit before putting pressure on it. Also...once its set or dry...do not spin that piece ever again or you will induce a leak by breaking the bod of the sealer.
If its flared AN fitting its supposed to seal on its own. I would relive the pressure...take it apart and clean up the mating surfaces a bit and put it back together tightly.
Old Aug 3, 2006 | 03:50 PM
thanks for all the help guys..
