Gauge install...sorry if its redundant
wait, does the 12 have to be connected to the dimmer? could it jus be connected to the light in the counsel? the light that comes on when you open the counsel. OR, maybe jus the battery?
Yea If you want the gauge to lit when your other gauges are the dimmer switch will be it. Some people uses a cable from the stereo but not sure wich one
careful dont forget to take the neg cable off the battery
well right now all I have is the nitrous pressure gauge. If I jus connected it to the battery wouldnt it just stay lit all the time once the was on? Or if I laced it into my ignition fuse it should just should just stay lit when i turn the car on? That seems to be my favorite way so far, lacing it into my ignition fuse. What do you think?
