How much spray?
Old Aug 6, 2006 | 08:42 PM
ggk's Avatar
ggk
Default How much spray?
how much spray would it take to go 10.99 in a stock wieght car?
it is a lt1 94 forumla with no power options, auto hard top car.
sorry to be asking but i am just wondering.
Old Aug 6, 2006 | 08:49 PM
00Vette's Avatar
There are way too many variables to say how much it would take.
Getting into the 10's is no small feat!
Old Aug 6, 2006 | 08:57 PM
383LQ4SS's Avatar
what rwhp all motor?
Whats stall?
Whats tires?
Track times on motor?
Old Aug 6, 2006 | 08:59 PM
SPRAYIN96TA's Avatar
whats the car weigh?? Does the car hook?? Is it a stick or auto?? If an auto, what stalll?? What gears, what kind of suspension.....I would think with full bolt-ons with heads and cam and a 150h it might run some low 11's...maybe pop out a high 10.9.....if you can drive..
Old Aug 6, 2006 | 09:00 PM
ggk's Avatar
ggk
stock car
it is a dd trying to keep it stock looking
Old Aug 6, 2006 | 09:04 PM
00Vette's Avatar
stock car
Your going to need a suspension setup to hook so you don't put the car into the wall from traction issues.
If you could get good traction and the car was stock (which I don't recommend for bigger than 150hp shot) you would need at least 200hp shot.........more like 250rwhp rated nitrous system!
Old Aug 6, 2006 | 09:07 PM
stock car
you will need slicks, good track prep and a **** LOAD OF NITROUS!!! 250hp+.....in other words......I highly doubt it will happen
ggk's Avatar
ggk
i have a hotchkis panard bar and i just replaced all the bushings in the rear.
i am going with a hollow front sway bar,i have a set of simmons wheels they are way lighter then the stock wheels( even with 275's on them and 235's on the stocks)
i havent raced it yet. i will be going to norwalk raceway parkway and from what i hear they prep the track pretty well.
what would let me to run a bigger shot like 250?
also i have a racetronix pump and harness.
Old Aug 6, 2006 | 09:35 PM
dude, I am not trying to be an ***......but I highly doubt even with a 250hp it will run 10.9's......EVEN IF it holds together........
Old Aug 6, 2006 | 09:43 PM
BadAzz96Z28's Avatar
I agree.....it would take more nitrous than that LT1 will handle to knock 3 or so seconds off n/a timeslip to see 10's. Good luck in your quest, dont be mad when you come up short.
Old Aug 6, 2006 | 09:50 PM
ggk's Avatar
ggk
i am not going to. i just was wondering.
ps i can build a motor for real cheap, beacause i can get the machining for free.
i just dont want to build the motor because i i plan i driving this car and cant really aford gas in the long term.
Old Aug 6, 2006 | 09:59 PM
boostedrs's Avatar
To get an LT1 with no major mods with just nitrous in the 10's I would say it would require forged internals and a helluva direct port nitrous kit with some killer tuning, suspension, and tires.
Old Aug 6, 2006 | 10:56 PM
Robert56's Avatar
How to get a stock '94 lt1 into the 10's stock, hmmm, a better way, sell the car and get a stock Z06 and put a 150 shot on and you'll see ten's.
Robert
Old Aug 6, 2006 | 11:53 PM
383LQ4SS's Avatar
I think you could do it with a hell of a stall and well tuned 200 shot and some weight reduction.
But if its your DD forget it. Youll be on the edge.
Old Aug 7, 2006 | 05:45 AM
chris.shea's Avatar
Robert
i hope plus as the rate vette prices took a dive anyone cant afford to not have one
Old Aug 7, 2006 | 11:39 AM
ggk's Avatar
ggk
yeah a vette is out of my price range.
how much hp would i need?
and what mods would let me run a big enought shot?
Old Aug 7, 2006 | 12:14 PM
383LQ4SS's Avatar
very good headers and good exhaust, stall matched to the goal/combo
cam/springs would be nice, basic bolt ons elsewhere.
And then a well tuned and set up 200 shot would likely do it along with weight reduction. Maybe a dual stage 100/100 to keep the stock bottom together.
With my fairly light SS and cam only longblock (with LS1 intake and remaining parts stock) I dynoed about 325 rwhp through the auto w 4200 stall and 460 on a 150-160 shot. It ran 10.2 at 130.
So I think a properly though out setup could sneak in the 10s near full weight. Its really more about the tires, stall and supsension. Just make 525 crank HP or so and set up the chassis and you can do it easily.
But you certainly wont be able to just add a ton of juice to your existing nearly stock car with stock stall and stock tires and stock suspension and get even close.
Old Aug 7, 2006 | 12:17 PM
Slow Z28's Avatar
383LQ4SS -
how light was that time?
Old Aug 7, 2006 | 12:21 PM
383LQ4SS's Avatar
probably 3300 raceweight (with me in it)
Suspension on that car was great. Motor and drivetrain was NOTHING special.
Local built Th400 with PI 4200 stall
Stock 2000 LS1 with a 228/232 cam
918 springs
rod bolts
Pacesetter headers
Magnoflow cat back ( no cutout even)
CAI
All other parts where stock including the ls1 intake
pulley
water pump
PS
heads
head gaskets
etc
keep in mind that HP through a t56 would have probably been like 360 all motor and 500 on juice roughly
So I think it can be done...but when shooting for an ET power production takes a back seat to properly set up chassis/stall. And that aint cheap either. Making the HP you needs to go high 10s really isnt that hard.
Old Aug 7, 2006 | 12:26 PM
ggk's Avatar
ggk
well i would like to run a 10 sec run but it would run to far away from what i would like to do with my car.
would a 100 or 150 shot at least bag me at least a low 12 run?
this would be on a set of slicks on the back. and on a well tuned car.
