mounting for micro/WOT switch
Old Aug 13, 2006 | 08:14 PM
BigDB's Avatar
Default mounting for micro/WOT switch
I have a mechanical WOT switch and for the life of me cant find a sutable spot to mount it. I originaly wanted it on the throttle body but cant find a position for it. Now im looking around the gas pedal and i see and bolt i could use but im worried i might break the switch if i slam the gas pedal down or maybe bend the bracket. any help would be great
Old Aug 13, 2006 | 08:20 PM
227Hawk's Avatar
You can mount it to the throttle body just takes some bracket tweaking.
Hawk
Old Aug 13, 2006 | 10:32 PM
Z2K_MrJ's Avatar
Board Certified Idiot
If your Car Has the trans Am Wheel Take Out the Damm Mute Button. Make it that aNice way for Push & go
Old Aug 14, 2006 | 12:05 AM
BigDB's Avatar
no its a standard z28 wheel, no stero controls. anyone with pics? i might have to go with a push button design
Old Aug 14, 2006 | 12:27 AM
Robert56's Avatar
In the wiring stickies is a pedal wot sw mount pics for f-bods, vettes, and GTO's.
Robert
Old Aug 14, 2006 | 12:40 AM
BigDB's Avatar
ya iv seen those but unfortunatly none resemble the setup ill have to make. Ima make a braket, just wanted to see what others with camaros did. Ill post a pic when its made, maybe u can put it in the sticky for others later
Old Aug 14, 2006 | 12:42 AM
Robert56's Avatar
Yes, that would be nice, thanks.
Robert
Old Aug 14, 2006 | 02:50 AM
code4's Avatar
I put some spacers & longer bolts on the bracket that is connected to the intake so that I could bolt on the micro switch. Here is a pic:
Old Aug 14, 2006 | 10:46 AM
BigDB's Avatar
thanks code4, thats something i was thinking of doing. the pic really helps. maybe if u get a side pic or angled robert will put it in the sticky possibly thanks
Old Aug 14, 2006 | 11:58 AM
FinalTA's Avatar
dunno if it helps or not, but this is what I did on my GTO:
