Lets See Some Clean Nitrous Installs!!!
For all you guys that are our customers please send your pics and info over to our new customer car section. http://www.nitrousoutlet.com/customerCars/help.asp
Courtnay is currently working on updating it.
Thanks
Dave
Thanks
Dave
Just wanted to Thank You for helping me get that missing Solenoid fitting. You must have some good pull with Nitrous Express, because they sent me two... Thanks again,, I also appreciated the tech advice. I have a new post with the install pics.
Jason
here is my dry setup i pieced together myself
2 powershot solenoids, with a microswitch under my gas pedal and a fan spray nozzle. i need to clean it up a little because it looks sloppy where i ran my wire for the relay but its pretty clean if you ask me
yep... 15lber w/ opener and heater.
I used a 10 wire weatherproof plugs for the solenoid wiring and an 8 wire plug for the bottle. New addition is an 8an stainless "blow down" to an 8an bulk head connector at the bottom of the spare tire well. Piece of cake in and out.
Robert
one of my favorites! great looking setups everyone, im looking into a direct port system eventually when i save up some money. keep the pics comming and thanks for the ideas!
https://ls1tech.com/forums/nitrous-oxide/564106-nitro-daves-plate-system-install-pics-c6.html
Dave
