~A Few Nitrous Questions~
How hard is nitrous on a motor when using all the safety precautions (fpss, window switch, WOT, bottle warmer, purge) Keep in mind i wont be spraying constantly! (except at first
) it will only be occasionaly on the streets when having some fun and maybe every now and then at the track. Also what is a good number to start with, I was thinking 100shot.
What is a good company to go with, I have had excelent luck with NX and will most likely go with them. But would like to know others experiences with other companies.
Now I need to know whether or not the direct port kit is worth the money? I dont mind saving up more to be safer. I want the kit to be hidden as much as possible, but not the most important thing.
Also i would like to know where i can order some tanks for a refilling station, i have a couple empty tanks in my garage, but have no idea where to get them filled. I always thought you have to have a license, but I'm not 100% sure about it. This isnt something i will buy right off the bat, but something to consider for the future.
Sorry about all the questions, and I appreicate all the help if any that I get.
Thanks again! Ryan
Thanks again! Ryan
From the research I have done and the input of many nitrous gurus on this site.........you can spray up to 150hp shot safely with all the safety equipment you have listed.
Now you need to get your kit from a reputable vendor so you can get good customer service when and if you need it. That is very important. It can really make or break your nitrous experience!
Your current setup and the amount you plan on spraying will depend on whether or not you will need bigger injectors (for a dry kit) or fuel pump (wet kit).
Post up your current mods and what your over all goal is for your setup! Do you want to spray a big shot or just a little. Do you want a nice fancy nitrous setup or just one to get the job done?
These questions will help me and others guide you to a good kit for your needs and help to advise you in what you'll need to run your kit as safely as possible.
I do alot of street racing for money...
so i dont want a set up to be easily visible, around here they only know what they see...they are a bunch of rich mommy and daddy kids who gets their cars handed to them on a silver platter. So I take there money by BSing them. I'll let one guy win a race knowing completely that i can take him and then stomp all over the next guy and take his money I do alot of street racing for money...
The money maker is about as good as it gets when you want a hidded nitrous system. The silinoids are built into the inside of the intake manifold.
Now that is some sneaky ****!
https://ls1tech.com/forums/showthrea...ht=money+maker
You can hide the lines with some time and patience and lots of people put the bottle in the fender well area. F-body guys can fill you in on that, or you can do a search on it.
IMO, direct port systems are the best ,and Dave makes some of the best. They are pricey, but I beleive you get what you pay for. I went with Dave's wet plate kit because I didn't have the money for a direct port system. I will get one one day.
You can go really big with a direct port system. Not to mention that our intake manifolds weren't designed to flow nitrous and fuel and directly injecting the two completely eliminates the possibility of it pooling in the intake manifold.If you plan on doing a full bolt on car with heads and cam you will need to upgrade your fuel system. Your current fuel system will not be up to the task of a full bolt on car and nitrous.
The only thing i dont like about the money maker system is that i wont be able to get to the solenoids very easily. Cant you send your solenoids back to NX and they will rebuild them for free once a year??
would i need to upgrade my fuel injectors for a 100 dry shot?
from what i have read the stock fuel pump should be ok, i know to get the window switch, regulator, purge, wot switch, etc.
the only thing im worried about is changing out the injectors, the most i plan on spraying is that 100 shot...
