Timing tuner question
Old Aug 22, 2006 | 08:27 PM
1BADAIR's Avatar
Default Timing tuner question
I tried the search but it don't seem to work.
I have seen the that max rpm can be 5900-7400
how do you set it to anything besides the mode 4 off(5900) and mode 4 on(6300)?
Old Aug 23, 2006 | 09:05 AM
Matt@HSW's Avatar
There is a process for setting the turn off RPM. There was an update a while back that allows you to set the turn off, what version manual were you looking at?
Matt
Old Aug 23, 2006 | 09:21 AM
1BADAIR's Avatar
Thanks
I just found my manual
I was using the one in the wiring section
Old Sep 10, 2006 | 09:01 PM
1BADAIR's Avatar
another question.
the manual says the red light will come on for 10 seconds then both leds will light for one second after turning th key on after setting the max rpm. I only seem to get both lights(1 sec) and not the red light for 10.
Old Sep 11, 2006 | 08:34 AM
Matt@HSW's Avatar
You will not see any lights, or at least I never have in the 30 or something we have installed, I belive it's a bug.
Matt
Old Sep 11, 2006 | 02:41 PM
1BADAIR's Avatar
ok. I was just worried I was doing something wrong cause I never seen the 10 sec red light before both lights came on
Old Sep 11, 2006 | 09:35 PM
silverZ98's Avatar
Originally Posted by 1BADAIR
another question.
mine was doing this too last year when i got it, sent it back to fullthortl and when it came back it worked just like the driection said it whould
Old Sep 11, 2006 | 09:38 PM
1BADAIR's Avatar
did it work before you sent it back or did the red light just not flash?
Old Sep 11, 2006 | 11:04 PM
silverZ98's Avatar
before i sent it back both light whould just flash real fast. now its 10sec like the directions say
