Thinking of Switching from DP to a wet shot...
Old Aug 27, 2006 | 05:40 AM
anarchy99's Avatar
Default Thinking of Switching from DP to a wet shot...
I'm thinking of switching from my DP setup to just a wet shot. The DP setup is just too much crap under the hood with the turbos also. The questions I have are these.
1) I'm only going to run 50,75,100 shots in this car since it's ontop of the turbos... If I use one nitrous silonoid and one fuel silonoid from my DP kit, will I run into any problems since it is such a large silonoid and a small shot?
2) Will I be able to keep my stand alone fuel system also?
3) on the stand alone fuel system, what fuel pressure would I run the regulator at? I think the DP setup was 10 PSI, would I need to keep it at 10 PSI or turn it down to like 5PSI?
Thanks guys and any help would be great.
Old Aug 29, 2006 | 01:02 AM
anarchy99's Avatar
T T T
Old Aug 30, 2006 | 02:41 AM
anarchy99's Avatar
You mean noone knows the answer to this?! Here's the pics of the solenoids and heres a sketch of what I'm switching to.
Attached Thumbnails Thinking of Switching from DP to a wet shot...-proposed-new-setup.jpg   Thinking of Switching from DP to a wet shot...-hereyahgo1.jpg
Old Aug 30, 2006 | 12:29 PM
CAT3's Avatar
Restricted User
Yes you can use the overkill noids. No you shouldnt experience any issues. Yes you can retain your standalone. Basically, remove the nozzles, the lines, the block/rails. Run new line from noids to the single nozzle, use appropriate sized jets and spray away.
Old Aug 30, 2006 | 12:54 PM
anarchy99's Avatar
Thank you !!!!!!!
Old Aug 30, 2006 | 01:47 PM
CAT3's Avatar
Restricted User
NETime Anarchy...sorry it took so long, been sorting thru unread posts, and kept getting kicked off the site for timeouts, after a few of them its log off time and reset my attitude
Old Aug 30, 2006 | 05:46 PM
anarchy99's Avatar
it's alright... I'm in montenegro right now so I've got all the time in the world...
