-Settle something once and for all-
Old Aug 31, 2006 | 01:15 AM
my01ws6's Avatar
Default -Settle something once and for all-
Ok im getting mixed answers about nitrous...some people tell me it completely destroys your motor while people on here swear by it. If used with all the safety equipment can you motor be harmed?
Can you guys tell me how long you have been using nitrous on your car, especially if its stock, being as mine is stock.
Also if anyone has any "horror stories" can you please share them.
Also if it matters im only going to be using nitrous on the street and maybe every now and then at the track.
Old Aug 31, 2006 | 04:11 AM
red90cobra's Avatar
read up on this part of the forum there's always good and bad story no matter what. yes you can be safe with it but there's always something that can go wrong with any power adder. read and learn.
Old Aug 31, 2006 | 07:18 AM
860 Performance's Avatar
It completely destroys your motor the first time you try it. I get a new motor every time I fill my bottle.
Of course it Doesn't! Why would everyone do it if that was the case! Please do a search and/or read the stickies.
Old Aug 31, 2006 | 09:05 AM
SPLATT's Avatar
Misconception...Nitrous somehow got labeled as some great destroyer of engines...probably the same reason its considered "cheating" haha. Of course there is a risk, But, if sprayed correctly and coreect safety equipment is used, then nitrous can be very adventageouos and fun...especially that torque anyway, have fun on the bottle if you do decide to go that way, but be warned, you wont be able to stop!
Old Aug 31, 2006 | 10:13 AM
blacktransam's Avatar
theres a bunch of topics at the top of this forum.. read them.. it will be much to your advantage..
mike
Old Aug 31, 2006 | 10:39 AM
Firechikn's Avatar
I have a big problem with n20.......
I can't fit a 100lb bottle on the rear deck.
Old Aug 31, 2006 | 10:47 AM
bottlefed01z28's Avatar
nitrous is lick crack to your car
my car's an addict
Old Aug 31, 2006 | 03:03 PM
my01ws6's Avatar
too all who said READ...i have been reading up on Nitrous for the past year or so...my question i want answered is this...Is it hard on your motor? and does it cause additional wear and tear on your motor?
Old Aug 31, 2006 | 03:18 PM
any time you increase horsepower.. weather it be cam.. lid.. anything you are being harder on the motor.. just think of it like a cold air intake worth 100-200hp
mike
Old Aug 31, 2006 | 04:17 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
mike
It's harder on them, but they can take it. It's not like a civic where its gonna explode on a 100 shot. People have pushed plenty through these motors and had them survive. Your sticky about how much can the stock bottom end takes addresses this.
Old Aug 31, 2006 | 05:58 PM
Specialized's Avatar
I plan on purchasing a TNT F1 kit and upgrading my FP and spraying 150-175 on stock components, then probably upgrading the fuel rails and the injectors and spraying 200-250 (sell the F1 and buy an F2)
Old Aug 31, 2006 | 06:06 PM
sprydncamd ta's Avatar
i spray a big shot and love it anytime you put a power adder on a motor it adds stress to the motor but the ls1's are proven to be able to handle it -Go big or go home-
Old Aug 31, 2006 | 11:21 PM
=ZoomZ='s Avatar
You can spray a 100 shot on the car all day long if its setup right and not hurt anything cept the tires .
150 shot will start to wear out the tranny or clutch but the motor will handle it just fine .
My stock bottom end , cam only motor held up just fine on a 200 shot but i had to step up to a stronger tranny.
Research and knowlage is the key to using nitrous safely .
Old Sep 1, 2006 | 12:24 AM
Blk97WS6's Avatar
nitrous is like a hot girl with an STD....you want to hit it, but your afraid of the consequences. but once you hit it, you are screwed. WHY?................because you keep going back for more and more.
Old Sep 3, 2006 | 12:50 AM
my01ws6's Avatar
LOL well what can the stock block take? 150? 100?
Old Sep 3, 2006 | 09:41 AM
=ZoomZ='s Avatar
https://ls1tech.com/forums/nitrous-oxide/551332-everything-nitrous-related-stock-bottom-end-wiring-everything.html
Old Sep 3, 2006 | 11:58 AM
SSDoubleK's Avatar
Wink
Bottom line, performance parts are not meant to last or fit as perfect as factory one's, everytiime you change something on a vehicle you must upgrade other components as well. Nitrous is Nitrous, take all your safety steps, and you will minimize the wear and tear on your motor, I would suggest to stay with a wet kit and make sure your A/F mixture is correct. Our motors can handle the juice rather well, I would not spray below 2700 rpms and run nothing higher than a 125shot, some members run higher and some run lower, also do not push it, the juice can either really help you or destroy you. Also make sure you read some of those horror stories on Nitrous Closely, alot of times not all safety steps were taken,and corners were cut, that's when you have problems, I had a buddy shift from fourth to third instead of fourth to fifth, and yes, he blew up the motor, stuff happens. Good luck.
Old Sep 3, 2006 | 12:53 PM
=ZoomZ='s Avatar
This makes no sence at all .
There would be no after market industry if Lunati , comp , Calies or the other hundred companies out there didnt make better parts than the stock ones .
We buy forged pistons , billet piston rods , hardened pushrods and forged cranks because stock factory parts cant handle our demands .
Old Sep 4, 2006 | 08:49 AM
one2run's Avatar
haha! nitrous is hard on a lot of things...
the clutch for the m6 guys and your wallet if you are addicted enough!
i will probably never see it on my car... it's hard enough to afford all the supporting parts for n/a horsepower! but i do get tempted from time to time.
i have done a lot of searching and research, and have found that if correctly set-up, it can give years of performance and fun. some even have claims of it cleaning up there high mileage motors by dusting off the tops of their pitons and swelling 'em up on every "hit"! HAHA!
Old Sep 4, 2006 | 10:59 AM
=ZoomZ='s Avatar
Its true , if you hear a funny noise in the engine/drivetrain , spray the **** out of it and it goes away ,, hahaha
I started spraying my last motor at 50k miles and i finaly took it off the road at 108k hard miles and built a bigger motor .
The old block is sitting at the shop and its just fine and ready to be rebuilt .
