Highest TREX nitrous dyno???
Old Sep 2, 2006 | 03:00 PM
slowredz's Avatar
Default Highest TREX nitrous dyno???
I know the TREX isnt the best pick for a nitrous cam. I was just curious who has made the most power with one and did you have any problems.
Old Sep 2, 2006 | 04:42 PM
BTLFEDSS's Avatar
subscribing
BTLFEDSS
Old Nov 20, 2006 | 08:20 PM
Hi Volume's Avatar
Curiousity made me bump this thread
Old Nov 21, 2006 | 04:34 PM
raymond mckinney's Avatar
I have the REX and a TNT 150 shot and made alittle over 500 wheel. But track times are the most that counts to me.
Old Nov 21, 2006 | 04:35 PM
And for problems theirs none and i drive my car daily.
Old Nov 21, 2006 | 04:42 PM
HaulinHawk's Avatar
Got any slips yet????????
Old Nov 21, 2006 | 05:02 PM
Lythropus's Avatar
How does the TREX drive? Surge Alot? Could you use a slightly smaller stall with it, 3600-3800?
Old Nov 21, 2006 | 08:30 PM
sciff5's Avatar
I asked a question along these lines and no one responded. I am hoping to run the PRC LS heads with the TREX cam with a 250 shot from a dual nozzle kit. Many have said that on smaller shots the TREX cam is fine but how bout larger shots in the 200-300 range? I have read of people seeing diminshing returns after a 200 shot with the TREX cam.
If the TREX isnt the best for this setup what other cam would be better that would produce a lot of power up top. This is going in a 2500lb weekend/ race car with 4.10s(so I dont need more torque). Drivability isnt that big of a deal but I dont want to have to change the valve springs every 5k miles or anything crazy like that
Old Nov 22, 2006 | 08:17 PM
I love driving my car it does surge alittle but i don't care. I guess u could run a smaller Stall but the Cam really needs 4000 plus stall i was thinking of going bigger. I don't know about the Trex and 200 shots but i will soon!! I would say if u want a big Cam and a 200plus shot i would run a MS3 or MS4, i've seen and read very good results about those Cams and Spray. As for slips the Cage is going in and i just got some slicks and skinnys so very soon i will have some 10 second time slips.
Old Nov 22, 2006 | 08:34 PM
Hocky's Avatar
I never dyno'd on the big shot, but I did ~565whp on a 150 shot. It had seen up to about a 275 shot.
Old Nov 24, 2006 | 06:10 PM
HaulinHawk's Avatar
BMP thurs dec 7th,last t&t for dec !!!!!Im there.
Old Nov 25, 2006 | 12:56 PM
Noyzee's Avatar
8 second mod
i made 703 with a t rex 2 years ago with my stock cube motor. went to a smaller esp-1 cam, and made 72x rwhp with a 300 shot on both dyno's.
Old Nov 26, 2006 | 07:53 PM
import slayer's Avatar
I cant wait to get the TNT F1 for my TA. I will be spraying with a 4400 stall and a 100 shot. Are you using a window switch? With your 4000 stall what does it flash to when you spray? What is your shift extension? and with a 4000 stall and a 150 shot have you ever run out of motor?
Old Nov 26, 2006 | 08:01 PM
calongo_SS's Avatar
I've got a 4k stall spraying a 150 tnt f1. I can't say for sure what it flashes to, I'm just holding on. Shift extension is high, around 6k + on the bottle, 5200 on motor. (shifts @ 6700).
Old Nov 28, 2006 | 12:56 AM
slowredz's Avatar
I made 639 on a 200 shot through a turbo 350 and 12 bolt with the TREX. I just changed cams and the 1st pull it made 687 on the same 200 and the next pull it lifted the heads. Ordering head studs any day now
Old Nov 28, 2006 | 11:07 AM
Nitro Dave's Nitrous Outlet's Avatar
I had the Trex is my ss with a 200 shot. However I do not remember the numbers on it. Ill see if I can find it.
Dave
